Jetro Posted February 4, 2007 Share Posted February 4, 2007 Does anybody using a SPA Fire extinguishing system with the electric activation know what the red light on the box marked system check means? I had the system in the car but recently took it out to do some work and reposition the bottle. When I connect all the electrical connections I get the red light. I don't think this is right. Any ideas? Quote Link to comment Share on other sites More sharing options...
scottbm3 Posted April 2, 2007 Share Posted April 2, 2007 Does anybody using a SPA Fire extinguishing system with the electric activation know what the red light on the box marked system check means? I had the system in the car but recently took it out to do some work and reposition the bottle. When I connect all the electrical connections I get the red light. I don't think this is right. Any ideas? If the red light comes on while in the test mode, you probably have a short in the wiring or bad button. While in the test mode the light should only come on when you press one of the buttons. Do NOT activate the system until you have checked al the wiring and switches. Quote Link to comment Share on other sites More sharing options...
