eclricochet Posted February 8, 2007 Share Posted February 8, 2007 I am looking at building a car for H4. I have a 1995 CX hatchback chassis and D16Z6. Even though the chassis is not the same code it is an identical chassis. What are the requirements to convert this since all of the things that make the difference between the SI and CX are removable? I did try searching but didn't really pull anything up. --Doug Quote Link to comment Share on other sites More sharing options...
civicrr Posted February 8, 2007 Share Posted February 8, 2007 did you read the Honda Challenge rules? the chassis swap is covered in the rules book. basically, swap over everything from the powertrain & suspension. engine, tranny, rear brakes/trailing arms you can leave the front brakes/knuckles alone or swap them out. the cx/dx brakes use the D273 pad. the better knuckle uses d617 pad which is larger. more importantly, it also uses a bigger front bearing & brake rotor. the Si was available with both .... Quote Link to comment Share on other sites More sharing options...
eclricochet Posted February 8, 2007 Author Share Posted February 8, 2007 I did read but wanted to make sure my interpretation of the rules were correct. Thanks --Doug Quote Link to comment Share on other sites More sharing options...
