introducing myself
scion tcx
Hello,
Wow, what a wealth of good information on here, thank you!
I drive a 2006 Scion tC, with a fully built turbo motor, upgraded clutch, brakes and suspension. I am a beginner when it comes to technical driving/hard racing and I'm looking forward to some track time and learning a lot this year.
Thanks again for providing a "safe" environment to ask questions, share ideas and learn.
Hello,
specs on motor?
Southern CA, Willow Springs, California Speedway.
motor was built around the Turbonetics T4/T5 turbo kit:
Internals:
CP turbo pistons 8.5:1 (balanced)
Carrillo forged rods (balanced)
custom ported & polished head
custom ground and coated cams
+1.5 mm titanium valves
high pressure valve springs
titanium valve retainers
ARP head bolts
Transmission:
Quaife limited slip differential
Clutchmasters Stage 2 clutch (balanced)
Clutchmasters lightweight flywheel
Suspension:
Front: Megan coilovers
Rear: TRD lowering springs/TRD shocks
TRD front strut bar
Hotchkis front/rear sway bars
17 x 8 VOLK CE28N titanium silver rims
235/40 Yokohama ADVAN Neova tires
Wilwood 13" big brakes (slotted & drilled rotors)
stainless brake lines
Performance (General):
Turbonetics T3/T4 E-50 turbo
Bosch 750cc injectors
Raptor blow off valve
TurboSmart Ultragate 38mm wastegate
Spearco W.A.V.E. intercooler
Stainless mandrel-bent downpipe
Ingalls engine torque dampener
Agency-Power crank pulley
TWM stage 2 short shifter
TWM weighted shift knob
Draxas stainless S pipe
Custom turbo-back 2.5" mandrel-bent exhaust / Magnaflow muffler/tip
eBoost2 boost gauge/controller
Haltech wideband Air/Fuel gauge
MoTeC ECU management
Custom wiring harness
Apexi turbo timer
Well, I can't honestly imagine getting that good, but I intend to learn and practise, so who knows.. I don't think it will be my vehicle holding me back, at least.
I've sene a video of him driving. He needs some work (don't we all) but he is pretty fast for just getting into the sene over the last year. He is fully caged so it looks like his setup has a one up on you and probably has you beat in safety and Tires as well.
I wouldn't worry about beating him though, just go out there and learn. I only mentioned Rado b/c I know he is driving a raced out TC and is around your area.
Here is some info/footage for you off of H-T
Buttonwillow
http://www.honda-tech.com/zerothread?id=1813011
Time Attack
http://www.honda-tech.com/zerothread?id=1812500
I've watched him drive as well. He's been very helpful to me with advice for my car, and I will be using his TBC-1 boost controller soon as well.
Here is my video clip (doesn't show that much driving, sorry) from Time Attack two weeks ago. Chris was using scramble boost and pumped it up just a bit too far (24+ pounds on a stock motor!) on the final straight section of his third hot lap.
Watch what happens: http://www.youtube.com/watch?v=uX-0N-6G7ZI
nice work with the clip.
I've heard those TC motors can hold their own. I thought about buying a TC and doing it up but then lost the itch after I heard about Honda Challenge Racing. I then started building my K20 civic.. .
Good luck with your tune.
I love boost too
blow it up real good
  • 3 weeks later...
