fs - Gauges rpm&speedo/Af/Oil psi/h2o temp
Posted (edited)
92-95 Civic EG gauge cluster setup and 3 Electrical gauges.
I don't want these anymores. They work. Came with the car shell when I baught it. Took out as soon as I did my K20 swap. Been in storage for a grip. I have a 3 pod A pillar that will cost you $20 more.. .
** OIL PSI and TEMP sensors not included
$25 for each gauge - Getem now!
$30 for the rpm and speed cluster stuff
I take paypal at
[email protected]
  • 3 weeks later...
Help me out here....I dont know anything about these. Is there a specific application for these gauges? What sending unit is needed for each ?
Thanks.
Info on gauges
*Only the Speedo and Tach are "Car Make" Specific, oil, H2o and A/F will work on any car.
*Will work just like any other Electric Gauge
*The Speedo and Tach gets very bright and comes with a dimmer (that lil grey box with that lil switch)
*You don’t have to run the speedo and tach gauge ad lil grey box for the other three gauges to work.. .
What you need for complete function of these gauges
*Run a master Power, Ground and Remote wire from somewhere in the dash and splice each gauge into those.
A/F – *hookup to power, remote and ground
*Hookup to your ECU’s 0-? Volt pin-out or find the 02 sensors sending wire.
Oil PSI – *hookup to power and remote wire to lil grey box, hookup ground *Buy a electric oil temp sensor
*Either drill & tap a hole in your oil pan or find some type of adapter to fit into a oil line *or on your oil filter
Water temp - *hookup to power and remote wire to lil grey box, hookup ground
*Buy an electric water temp sensor
I personally don’t like the way these gauges look which is the only reason why I am really selling them. Otherwise, these gauges would work fine for any car.. .
