Dawg Posted February 26, 2007 Posted February 26, 2007 got an 03 cobra and want to side exhaust the car; but my hold up is i have a lower chassis stiffener ( about 1" round) that i have to work around. any other suggestions? i want to keep under the sound limitations too! THANKS. Quote
marshallmosty Posted February 26, 2007 Posted February 26, 2007 I used Dr. Gas frame clearance tubes. They can pretty much make anything you need. It gives approx 0.5" more ground clearance versus standard round tube. I used it to clear my torque arm mount. Quote
Dawg Posted February 26, 2007 Author Posted February 26, 2007 thanks man wish i had the time to be in depth like most of ya'll. i wanted to run side exhaust because i seem to be having trouble out of my irs overheating. scared of the solid axle; since i'm used to the irs. don't want to be bopping around the place on the curbing and so forth; from what i've heard. i seem to like the curbs sometimes. Quote
Dawg Posted February 26, 2007 Author Posted February 26, 2007 also enjoyed the videos on the texas stuff. some good hands there! Quote
99cobra2881 Posted February 26, 2007 Posted February 26, 2007 Do you have a diff cooler setup on the car? Quote
Dawg Posted February 26, 2007 Author Posted February 26, 2007 i meant to say that i did. with a pump and fan. i mounted it on the rear bumper. cut a hole where the cobra badge was and mounted the diff. and trans. cooler there. i guess it doesn't get much air flow. tried putting a scoop underneath to bring air flow up but didn't exactly help. i don't want to move everthing up front; but might have to. Quote
white_2kgt Posted February 26, 2007 Posted February 26, 2007 i meant to say that i did. with a pump and fan. i mounted it on the rear bumper. cut a hole where the cobra badge was and mounted the diff. and trans. cooler there. i guess it doesn't get much air flow. tried putting a scoop underneath to bring air flow up but didn't exactly help. i don't want to move everthing up front; but might have to. why not just put it in the trunk w/ a fan and some NACA ducts to bring in airflow from the 1/4 window area? Quote
99cobra2881 Posted February 26, 2007 Posted February 26, 2007 Air has to be able to get out of the trunk somehow for the ducts/fan to be effective at cooling. I've removed the trunk seal and am considering drilling a few holes out of sight on the bottom of the trunk lid to help vent air out of the trunk. Quote
