Dawg Posted March 4, 2007 Posted March 4, 2007 are upper sub-frame connectors legal in ttu? i've got an 2003 mustang cobra and you have to cut into the floor pan above where a lower sub-frame connector would go and and put in the upper and weld in place and weld to the rear section of the body. these are used in world challenge cars. also what is the most g's seen in a mustang? is 1.4 g's out of the question at like an autocross event? would appreciate your responses! thanks! Quote
kbrew8991 Posted March 4, 2007 Posted March 4, 2007 for TTU, just stay under the proper adjusted power:weight and do whatever you want Quote
Dawg Posted March 4, 2007 Author Posted March 4, 2007 man that was fast! if you drive as fast as you answer posts you must be pretty good! was just reading the rules earlier and it was talking about the difference between ttu and ttr and it stated something about keeping the original floor pan and said something about" partial" or all tube frame would be basically ttr. was just figuring that the upper sub-frames would be both. what about the g's questions? Quote
StealthTT Posted March 5, 2007 Posted March 5, 2007 Pretty sure that you have to "retain" the stock floor pan to stay out of TTU or TTR. There was a thread where a guy welded a bar between the lower ends of the main hoop. He went straight through the tranny tunnel hump and then welded back around it. I'm 90% sure it was illegal because he modified the stock floor. Quote
National Staff Greg G. Posted March 6, 2007 National Staff Posted March 6, 2007 Photos needed!!! Quote
Thom_S Posted March 6, 2007 Posted March 6, 2007 Greg, I think this is what he is talking about... http://people.ucsc.edu/~kbrandt/mustang/InternalSFC.shtml Quote
Dawg Posted March 7, 2007 Author Posted March 7, 2007 BINGO!!!!!!!!!!!!!!!!! That's what I did. did i flub up for the TTU class??????????????????? Quote
National Staff Greg G. Posted March 7, 2007 National Staff Posted March 7, 2007 BINGO!!!!!!!!!!!!!!!!! That's what I did. did i flub up for the TTU class??????????????????? Yep, I think you might have. The modification is legal in AI under a special provision in the AI Rules. I have taken this one "upstairs", and so far, the concensus is that this type of modification is too much of a "slippery slope" to allow. This is not my final ruling.....yet. I'll keep you posted here. Quote
Dawg Posted March 7, 2007 Author Posted March 7, 2007 the reason i put it on was that i wasn't going to use a front strut tower brace. say that three times real fast. Quote
National Staff Greg G. Posted June 4, 2007 National Staff Posted June 4, 2007 Floorpan modifications to include items such as subframe connectors, roll cage bracing, and fuel cell placement may be approved on a case-by-case basis by the National TT (or ST) Director. Such modifications will be subject to approval and possible modification factor assessments. I am going to assign a -0.2 modification factor to these "upper subframe" modifications (as shown in the photos linked) through the floorpan in Mustangs. Quote
