1995 Civic SI hatch with Built ITR swap Race Car
RedheadRacing
The car was in a crash this last season. Hit a guard rail.
The car need the front end repaired. Other then that the car is in great shape no rust at all.
Motor has 6 races on it and it was always on the podium.
I am asking $8500 plus shipping.
Here is a link to some pics of the cage and the damage.
http://picasaweb.google.com/1995egsi/CrashedCivic
[email protected]
1995 Honda Civic SI
* Engine swap: B18C5 JDM (Japanese Domestic Market) 1.8L 4 cylinder 1998 Spec sleeved out to a 2.0L
* Mugen thermostat / thermoswitch
* Spoon Sport Magnetic drain plugs
* King Motorsports Head Job, 3 Angle valve job, Hot Tank, Port and Polish
* Import Builders "Killer Block"
* Skunk2 Stage 3 cams
* Skunk2 valve train
* R/C 550cc injectors
* Bored out Throttle body
* Port Matched Intake Manifold
* Hondata S200 ECU tuned by King Motorsports.
* Custom straight exhaust
* Oil Cooler with remote oil filter
* Unorthodox Racing crank pulley
* Fluidyne radiator
* Clutchmasters lightened Flywheel
* AEM fuel pressure riser
* Mugen Oil Pan
* Comptech Ice Box / Intake
* Exedy organic clutch
* Catch Can
* Password JDM intake gasket & cam seal
* Kosi K1 rims 15x6.5 Kumho Hoosier
* JIC Magic FLT-A2 coilovers
* Password JDM front upper strut bar
* Password JDM rear CF wing
* A-spec racing rear tie bar
* Benen Industries Strong Bar, front frame brace
* JDM Integra Type R Front sway bar
* Skunk 2 Rear sway bar
* Beaks rear sway bar reinforcement kit
* Goodridge steel braided brake lines
* Fastbrakes front big brake kit
* Brembo front and rear rotors
* Energy Suspension bushings
* Solid motor mounts
* 8 Point Custom welded roll cage with NASCAR style door bar, dash bar, x brace passenger door bar
* Custom dash with SPA guages
* Skunk2 Short shifter with Skunk2 shift knob
* Simpson 5 cam lock harness
* Momo Champion racing steering wheel
* Master Kill Switch not hooked up
* Corbeau FX1 racing seat
With some work on the front end the car would make a great HC car. Car is very sold other then the front end damage.
  • 3 weeks later...
