WTB Early 944 or 924S Belly Pan
genikz
The early aluminum pans come in 2 forms. One for the 924S and one for the early 944. The difference is that the uprights are much wider for the 944 and will not fit on the 924S without cutting them.
My pan is from an 87 924S. However I cut the sides off to make room for brake ducts so I am certain you can do that any sheet metal tray to make them work on any 924S or early tub. Heck since it is sheet metal if you need to just drill holes in the tray where needed to bolt to the crossmember and radiator support. Heck it would take what 5 min with drill.
Agreed. I picked up an early belly pan from Frank and I'll be triming it to clear my sway bar and anything else it hits. The rad and crossmember mounts match up just fine.
