AudiOn19s Posted April 5, 2007 Share Posted April 5, 2007 In particular this is in reference to a porsche 996. I'm looking at a Bilstein damper setup with off-the-shelf valving with the following values: Front: Compression 950N / Rebound 1850N Rear: Compression 3000N / Rebound 2000N This is a DE / weekend car and I'm thinking about rates of 600 f / 800 R. When I spoke with Bilstein they really couldn't tell me what I should run with the off-the-shelf valving becaue for most applications they custom valve them to whatever spring rate is chosen. (for an additional fee). This would be fine if I were ordering them new but I'm looking to pick these up off of a friend (never used and no springs were ever purchased for them)and want to know if i can run the spring rates listed above without changing the valving or if I should send them off to be custom valved anyhow. Thanks Quote Link to comment Share on other sites More sharing options...
