FS 84 VW Rabbit GTI-Cup Racecar $2800 obo (NorCal) SOLD!
sneville44
SOLD! Thanks for looking!
FS 84 VW Rabbit GTI-Cup Race Car $2800 obo
Raced in NorCal in NASA's GTI-Cup Series.
2006 and 2004 Championship Car
Eligible in Performance Touring (PTF) and GTS-1
This would also make a GREAT inexpensive track car, runs strong and is very reliable with some nice safety features.
The handling is forgiving and is perfect for someone learning to performance drive.
2:12.xx Thunderhill (w/NASA bypass)
2:04.xx Infineon (long Turn 7)
Will likely do close to a 2:00.xx Infineon w/ regular configuration
Well maintained with detailed records
NASA Logbook
Strong Running Engine 1.8L JH with Dougherty Racing Cam and Header
5-Speed Close Ratio Tranny
Oil Cooler and Cold Air Inlet
Baffled Oil Pan
K&N Air Filter
Neuspeed Short Shift
Neuspeed Upper Front Shock Brace
Neuspeed Lower Tie Bar
Poly bushings and Engine Mounts
Stainless Steel Braided Brake Lines
Front air dam with cooling ducts
Custom exhaust with Borla Muffler
Coilovers with recently rebuilt Bilstein Sport Shocks
28mm Rear Neuspeed Swaybar
Brand New Clutch (February 2007)
Kirkey Race Seat
Crow 5-point Latch Harness good until Feb 2008
G-Force Window Net (good until 12-07)
Grant Steering Wheel
Wink 5-panel mirror
Fire Extinguisher
VDO Tach with Shift Light
VDO Gauges OP, WT, OT & Voltmeter
Angled Dash Mount for HotLap Timer
8 point Safety Devices Bolt-in Cage with custom weld-in door bars
Upgraded 68mm Front Wheel Bearings/hubs (Audi 4000)
Hawk Blue Front Pads
Bosch Blue Coil (new)
Newer Radiator, ATA Master Cylinder, Fuel Pump, Oil Pump, Wheel Bearings & Rear Brake Shoes
Includes various spare parts: Used 1.8L long block, brake parts, front wheel bearings (2), air dam, passenger seat with 5-point Crow harness, (7) 14-inch VW snowflake rims (4 mounted with used Toyo RA-1s).
Car located in Sacramento, CA
Contact Scott Neville
[email protected]
916-837-7350 (cell)
