Guest Posted April 17, 2007 Share Posted April 17, 2007 I've been instructing for NASA for awhile, and bought a car over the winter. I'd like to register it w/ NASA and race w/ you guys. It is a 1998 Firebird w/ the LS1. It was registered in SCCA as ITE. I think the specs on it are 400hp and 3200#. Should it be in CMC 2 or AI or AIX? Quote Link to comment Share on other sites More sharing options...
99cobra2881 Posted April 17, 2007 Share Posted April 17, 2007 I have an ITE Mustang, the HP levels it has are similar to what you posted. Im going to be running in AIX. Quote Link to comment Share on other sites More sharing options...
racercosmo Posted April 18, 2007 Share Posted April 18, 2007 If the 400 hp is BHP, then you should come out around 350ish at the wheels. Is the 3200# with or without a driver? If it is without, then you should have no problem in AI. If it's with, then maybe some extra weight and/or a restrictor will get you into specs. Quote Link to comment Share on other sites More sharing options...
King Matt Posted April 18, 2007 Share Posted April 18, 2007 Depending on the level of prep on the chassis and suspension, it might be a candidate for CMC-2 if it has not been too extensively modified away from stock. You would probably need to detune the engine, but that may be easier and cheaper than building up to AI or AIX levels of prep. It might end up being a good fit for AI too, but I think you will find that AIX is not a very fun place to be if ALL you have is an AIX engine. Quote Link to comment Share on other sites More sharing options...
Raybob9289 Posted April 18, 2007 Share Posted April 18, 2007 Your car is right about were a good AI LS1 4th gen should be. You should get with Mike Patterson because he has a Camaro version of your car. If you were to gut the car down you might need a Restricter plate and/or add some balast. My 96 LT1 is makin 430 at the crank and 352 at the RW's. This winter I put it on the Jenny Craig work out plan and then had to add 75lbs back in balast. Long story short, put an AI on the side and Boogedy, Boogedy, lets go racin !!!!! Quote Link to comment Share on other sites More sharing options...
Guest Posted April 18, 2007 Share Posted April 18, 2007 Thanks guys. I would rather add ballast than detune or run a restrictor. That doesn't seem right. I want to go as fast as the car will go. It doesn't matter at this point if everyone is passing me. I'll probably end up in AI. I'm going to race @ Summit Point in 2 weeks w/ SCCA. Some of the guys race in both series, so I'll continue to ask around. Quote Link to comment Share on other sites More sharing options...
Renntag Posted April 19, 2007 Share Posted April 19, 2007 I think you will be bast fit for AI fwiw, given the power your car already makes. I instruct at summit frequently and might see you in the Paddock at the SCCA race. What colour/number is your car? Best of luck. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 19, 2007 Share Posted April 19, 2007 Colin, It looks like we both have yellow cars. Mine has a big red stripe down the middle. I'll see you on the 28th. How early do I have to get there to get a spot on the pavement? Quote Link to comment Share on other sites More sharing options...
Renntag Posted April 20, 2007 Share Posted April 20, 2007 The paddock is coordinated by Mike Collins and groups are equally given assigned sections of the paddock. To get a spot to your liking you need to get there early and then see what section is available to you. This was the only way to keep the peace. Quote Link to comment Share on other sites More sharing options...
