genikz Posted April 29, 2007 Share Posted April 29, 2007 I know this is long, but I need some second opinions guys So, after two HPDE events and one Auto-X, I fear I need to re-index my rear t-bars. I'm not rubbing, bottoming out or hitting the bump stops (as far as I can tell), but I'm getting a *clunk* sound from the back of the car when the rear suspension is fully loaded and I hit a bump or the curbing. It's not a constant noise; it sounds like maybe the sway bar hit the curbing and gave me one solid *thump*. Though there are no signs of the rear sway actually hitting... Here's the twist though, I bought rebuilt axles from Kragen and installed them before my last HPDE (Buttonwillow). Prior to this event, I was running old axles and didn't hear the same *clunk*, though I was at the same ride height. This was at Cal Speedway and didn't hear this noise at all...though Buttonwillow has much more curbing, and I was taking advantage of clipping them. I'm thinking maybe the new CV's are 'tighter' and therefore binding when I load one wheel really hard. Would a CV give me a *clunk* though when it's maxed out angle-wise? I imagine it would, considering it has a max angle of movement and I appear to be reaching it. If I raise the car an inch or two, I would level the axles much more (in relation to the ground), and in turn hopefully not reach the max angle I currently reach. I only have about 0.5 inches room to go up though, in the spring plates, so I'll have to re-index if it is in fact too low. For reference, my 88 924S rear has: 30mm t-bars Welt torsion tube\carrier bushings Koni yellows, adjusted about 1/3 from full-soft 15x7 phonies 215/50/15 street tires Any other opinions or possible solutions? I'm reluctant to re-index the rear, since it was such a PITA. Anybody else really low with no issues? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
genikz Posted April 29, 2007 Author Share Posted April 29, 2007 Quote Link to comment Share on other sites More sharing options...
Chuck T. Posted May 1, 2007 Share Posted May 1, 2007 Too Low. Quote Link to comment Share on other sites More sharing options...
genikz Posted May 1, 2007 Author Share Posted May 1, 2007 Agreed. I took another look tonight and It's going up about 1.5 - 2 inches in a month or two. Quote Link to comment Share on other sites More sharing options...
