Pat L. Posted May 12, 2007 Share Posted May 12, 2007 Basically everything you need to go run AI minus a rolling chassis. This 327 small block Ford powered the #117 AI mustang to back-to-back victories at Cal Speedway March 17/18. Uncorked it makes 350/332 to the wheels on a dynojet. There are less than 7 hours on this motor including dyno time. Motor: Ford 327 4340 crank H-beam rods Probe flat-top pistons Main girddle and windage tray Canton pan TFS heads with lots of work Hydraulic verticle-bar lifters Comp roller rockers 7/16 studs Chromoly pushrods Air Gap intake Sheetmetal valvecovers Vic Jr. water pump All accessories are complete & on the motor (ready to go) Fresh Air box and filter for 2" cowl (GORGEOUS, see picture) Restrictor MSD distributor Crane Hi6 ignition BBK long tube headers for Fox mustang Flywheel (external balanced) Price without carb: $5200 Price with carb: $5650 Transmission: Tremec TKO 5 speed. Shifts beautifully. Tilton 7.25" tripple-disc clutch, brand new in March (two races old). Tilton Throwout bearing. Lots of Tilton spares. Also, aluminum driveshaft with all u-joints and flanges & Pro 5.0 shifter. Price: $1700 I'd like to do a package deal so please make an offer. Items are located in Bakersfield, 93313. Quote Link to comment Share on other sites More sharing options...
JKnight Posted May 15, 2007 Share Posted May 15, 2007 You know, Mrs. Knight was just saying that she's sick of dealing with dead optisparks, and this combo makes almost exactly the same power the current engine makes...think it would fit into a Camaro? I kid. Jason Quote Link to comment Share on other sites More sharing options...
Pat L. Posted May 15, 2007 Author Share Posted May 15, 2007 OMG, dude you had me lmao pretty good... nicely played Quote Link to comment Share on other sites More sharing options...
