JW Racing Posted June 10, 2007 Posted June 10, 2007 Hey, under the roll cage section in the CCR it says head restraint... this means donut,hans device etc. correct? I just want to know if i have to weld a sheetmetal wall to pad around the head area? because it says 36 inch square area,thats unclear to me. Quote
Bruce L. Posted June 10, 2007 Posted June 10, 2007 15.6.21 refers to a plate behind your helmet if you have a low-back seat (old style). If you have a typical high back seat, you don't need anything else to comply. bruce Quote
JW Racing Posted June 10, 2007 Author Posted June 10, 2007 Ah so im fine with the sparco seat... got ya. thank you kindly Quote
nasaregistrar Posted June 11, 2007 Posted June 11, 2007 Ah so im fine with the sparco seat... got ya. thank you kindly Do not forget the SIDE restraint rule that takes effect July 1, 2007 Quote
JW Racing Posted June 11, 2007 Author Posted June 11, 2007 Yes, thank you. i have the window side i just need the center net. Quote
