mweeks Posted June 15, 2007 Posted June 15, 2007 My wife is forcing me to sell my car, so here it is. 1983 944 Spec 944 The car is RED in color, it is completely gutted inside. There are NO windows in the doors, no head lights or wipers The body and paint are in very good condition. In addition the car has; SUSPENSION: Front Coil Overs with 400lbs spings Koni Inserts Weltmiester Camber Plates New Ball Joints Weltmiester Poly Control Arm Bushings M030 Front Sway Bar with Delrin Bushings Tarrett Sway Bar Braces Manual Steering Rack with Delrin Bushings 31mm Hollow Torsion Bars Complete Weltmiester Poly Bushings M030 Adjustable Rear Sway Bar w/ Delrin Bushing Adjustable Drop Links NEW Koni Shocks WHEELS: Polished Phone Dials TOYO RA-1 Tires with 4 heat cycles INTERIOR: Kirkey Road Race Seat (Driver) Kirket Intermediate Seat ( Passenger) MOMO Steering Wheel w/quick release WINK 5 panel Mirror Autometer Gauges 5 Point Belt Harnesses ( Out dated for racing) Autopower Bolt-In Cage BRAKES: Brembo Cross Drilled Front Rotors Custom Brake Ducts Stainless Steel Brake Lines The car also has an RX-7 external oil cooler, new radiator, MSD 6AL Ignition Box, MSD Blaster Coil. There is probably more, but I can't think of it now. All you need to do is put in an engine and you will have a great car. $3750 obo Quote
