Bruce L. Posted June 23, 2007 Posted June 23, 2007 what does the ccr or your series rules book say? pdf search is your friend. Most series that I know of do require the steering wheel lock to be removed. bruce Quote
Weston Posted June 23, 2007 Posted June 23, 2007 Yes, it needs to be removed. It's easy on the 924S and early 944... just pull it out and use a Dremel to cut the "pin" off and grind it down a little so that nothing will catch in the steering shaft. If it's a late 944, I believe it's more difficult to get the ignition switch out, but I don't know the procedure off the top of my head. Quote
dmdirks Posted June 24, 2007 Posted June 24, 2007 Actually, according to section 14.8 of the 944-Spec rules, "...the steering lock may be removed..." which is different from the mandatory removal requirement for the Cup series (section 8.2.3.) Quote
Weston Posted June 24, 2007 Posted June 24, 2007 Actually, according to section 14.8 of the 944-Spec rules, "...the steering lock may be removed..." which is different from the mandatory removal requirement for the Cup series (section 8.2.3.) This is where it gets a little confusing... the 944 rules say "may", but the CCR says "shall"... 15.9 Steering Wheel LockThe steering wheel locks shall be removed except where authorized by class rules or by exception from the Race Director. My interpretation is that the "may" in the class rules only authorizes removal of the lock, not non-removal as an exception to the CCR, but it's really not clear. Quote
JerryW Posted June 24, 2007 Posted June 24, 2007 In the CCR's the last sentence of section 1.0 states: All competition class rules and local supplemental rules supersede the CCR whenever there is a conflict. Therefore if our Class rules specify MAY they superscede the CCR's stating SHALL. Or at least that is how I read it. Quote
Chuck T. Posted June 25, 2007 Posted June 25, 2007 In the CCR's the last sentence of section 1.0 states: All competition class rules and local supplemental rules supersede the CCR whenever there is a conflict. Therefore if our Class rules specify MAY they superscede the CCR's stating SHALL. Or at least that is how I read it. This is correct. So 944-spec MAY remove it not required. Quote
Tim Comeau Posted June 26, 2007 Posted June 26, 2007 Excellent work, Chuck and Jerry. I love the way our forum is both informative and self-correcting. Thanks for serving the class, Guys! GOOD ON YOU! Quote
