greg f Posted June 29, 2007 Posted June 29, 2007 Ahhh, but it is not the same for everyone. Those with rings and cylinder walls in primo condition will have way less blow by than those with a season or two on their engines. I do not personally believe that a crank scraper will make as much difference on a 944 engine as some other types. It already has a reasonable windage tray to stop the worst situation, where oil rushes forward under braking and is captured by the spinning crankshaft. I think that any power gained is actually just not losing power due to internal friction and heat. So you have a situation where an allowed, expensive mod ( 88 oil pan and baffle) could make more power than the same engine with a standard pan and baffle. My cost on a new late pan and baffle is $550. Allowing the inexpensive mods for your next rules go-round would seem to level the playing field for the non 88 pan guys. Greg Quote
