1996 Mystic Mustang Cobra
I am posting this for a friend. I ran with him at VIR recently and got to ride in this car. It is a very capable track car that is still streetable. The car is running perfectly, as he has fixed all the little bugs it had when he purchased it. Everything on the car works, a/c, power window, power locks, cruise control, etc. The car just turned 75,000 miles. Now on to the goodies, I most likely will forget some things, as the list is rather long.
Within the last 3 months, the car has had:
New fuel pump, filter, and gas tank gaskets.
new rear bilsten shocks
New steering pump and high pressure lines
New rear end c-clips, gaskets, fluid
Engine:
Steeda underdrive pullies
K&N Filter
New Plugs
New Ford Wires
Canton 7qt with windage tray oil pan
SCT dyno tune - 308 rwhp 303 rwtq
Exhaust:
BBK long tube headers
Bassani O/R x-pipe
Magnaflow Catback
Suspension: (same as MM "grip in a box package")
I know I am missing some things.....
Griggs K-Member
Griggs Lower control Arms
Griggs Coil-Overs at all 4 corner
Maximum Motorsports C/C plates
MM FLSFC's
MM Torque Arm
MM Panhard bar
MM rear lower arms
MM front sway bar
Odds and Ends:
Braided Brake lines
Pro 5.0 shifter
Fluidyne Radiator, override on the fan switch
4.10 rear gears
New Spec clutch
Recaro "cobra R" front seats
Autopower 4-point rollbar with all extras (tubes and thickness)
6-point driver harness
5-point pass harness
Fuel Press, water and oil temp gauges
class I hitch
Kenwood indash radio with component speakers and sub
Extras:
I have tons of extra parts/spares
Race stuff:
Tons of extra pads/rotors
6 cobra R 17x9 rims with very slightly used Avon Tech R tires
4x5 utility trailer with tire rack and storage unit
The car is by no means a trailer queen, she has 75000 miles,and there are rock chips, scratches and such. But he took good care of car, detailed the car a few times, and it looks really good.
Price for car and everything listed above $14,900 which is a steal IMHO.
$11,900 for just the car minus all the extras, the rollbar, harnesses and recaro's.
Here are a few pics.
http://i98.photobucket.com/albums/l265/mojosvt/BuckeyestangsAug4th2007010.jpg
http://i98.photobucket.com/albums/l265/mojosvt/Mysticdetailbeforesummit010.jpg
http://i98.photobucket.com/albums/l265/mojosvt/Mysticdetailbeforesummit011.jpg
http://i98.photobucket.com/albums/l265/mojosvt/mysticinterior005.jpg
http://i98.photobucket.com/albums/l265/mojosvt/mysticinterior008.jpg
http://i98.photobucket.com/albums/l265/mojosvt/mysticinterior001.jpg
http://i98.photobucket.com/albums/l265/mojosvt/ovrscca.jpg
http://i98.photobucket.com/albums/l265/mojosvt/VIR2007010.jpg
http://i98.photobucket.com/albums/l265/mojosvt/vir1.jpg
You can contact him at [email protected]
The car is located in Columbus, OH
