mcmurdy Posted May 20, 2003 Share Posted May 20, 2003 FOR SALE 1985-1 944 $10,000 Firm 602-765-6755 - [email protected] New Ignition Components: ignition coil; distributor cap; ignition rotor; ignition wire set; New Cooling System Components: radiator; radiator mounts; radiator fan switch; reservoir; reservoir hose; Thermostat; Rebuilt water pump New Engine Components: Rod bearings and oil cooler seals; oil pan gasket; oil filter; oil drain pan gasket; oil filter stand gasket; oil cooler grommet; oil cooler O-ring; Front Engine Seals; Cam seal; counter balance shaft seal; Counter balanced housing front O-ring; Counter balance shaft seal lower; Front crank seal; oil pump O-ring; Front cam housing grommet; Camshaft bolt;; cam belt idler; counter balance shaft tensioner; counter balance shaft idler; Cam belt tensioner; Timing belt; Counter balance shaft belt; Belt Cover (used); All engine work performed by Exotic Motorwerks, Phoenix, Arizona New Brake Components: Stainless steel brake lines; brake pads New Suspension Components: Racer's Edge Camber Plates; Koni Sport Shocks; Koni Sport Insert; Weltmeister 400 lb. Springs; 30mm torsion bars; 28 mm front sway bar; 21mm rear sway bar; Control arm bushings; reinforced control arms New Power Steering Components: Rebuilt rack; power steering hose; Miscellaneous New Components: Kill switch; Fuel port; AC delete bracket and belt; clutch pedal bushing; external fuel filter; internal fuel filter; Momo steering wheel; CV joints; Axle boot kit; Motor Mounts; Momo seat Bolt in Roll Cage Car is very clean. Since all of the foregoing work was performed the car only has two auto-cross events, and four race days. One of the race days involved heavy ran and the car was run very lightly. Quote Link to comment Share on other sites More sharing options...
