MikeV Posted October 6, 2007 Share Posted October 6, 2007 I have a short block from an '87 924S, has been bored and new 2nd oversize pistons before I owned it. No scoring on cylinders and pistons still look new. Asking $400, $500 for long block OBO. Located in southern NH. Thanks for looking. Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted October 8, 2007 Share Posted October 8, 2007 For reference. 944 spec motors are not allowed to overbore. Bore must be the orginal standard size and tolerance group 0,1,2 Factory size overbores are allowed in 944 cup. Quote Link to comment Share on other sites More sharing options...
MikeV Posted October 8, 2007 Author Share Posted October 8, 2007 Thanks for the reference. The tolerance group is 2, it has the factory stamp is on the block. Quote Link to comment Share on other sites More sharing options...
944-Spec#94 Posted October 8, 2007 Share Posted October 8, 2007 That may not be overbored then. The factory bore is 100 mm. However normal tolerancing allowances required them to use 3 tolerance groups. They are labled 0, 1, 2. The numbers are stamped into the block and in to each piston. Most engines are 0 or 1. Some are 2. These area not overbored since they are 100 mm +/- a tiny amount. (I think .01 mm or so) The factory overbores dimensions are 100.5 and 101 mm and thus considerably larger. Quote Link to comment Share on other sites More sharing options...
