Lemming Posted October 9, 2007 Share Posted October 9, 2007 No, I didn't get rid of my Frankencar. A good friend is going to run his '04 Z06 at Barber this weekend and asked me to classify his car. Base class is TTA* and he has an additional 15 points in mods. This pushes him up one class, does that mean he goes to TTU? Why are some Z06's running in TTR? Quote Link to comment Share on other sites More sharing options...
John Graber Posted October 9, 2007 Share Posted October 9, 2007 It means he needs a certified dyno to be officially classed in TTS or TTU depending on the power. If he doesn't have one he would run in TTR. Quote Link to comment Share on other sites More sharing options...
Lemming Posted October 9, 2007 Author Share Posted October 9, 2007 Thanks John! Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted October 9, 2007 Share Posted October 9, 2007 yep, TTS (8.7lbs:hp adjusted) is the next class up from TTA TTU is a pretty silly fast class (5.5lbs:hp adjusted) Quote Link to comment Share on other sites More sharing options...
Lemming Posted October 9, 2007 Author Share Posted October 9, 2007 yep, TTS (8.7lbs:hp adjusted) is the next class up from TTA TTU is a pretty silly fast class (5.5lbs:hp adjusted) I doubt that he is not going to want to get a dyno before the weekend, so I suggested that he run TTR. No one is signed up for TTR this weekend, so he might get both first and last place Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted October 9, 2007 Share Posted October 9, 2007 eh, its a thought... I don't know that the TTS guys will complain if he runs in S because he is bumped out of A by points. can he shed 2 points easily? Quote Link to comment Share on other sites More sharing options...
Lemming Posted October 9, 2007 Author Share Posted October 9, 2007 eh, its a thought... I don't know that the TTS guys will complain if he runs in S because he is bumped out of A by points. can he shed 2 points easily? No, his points are coming from running 315 Hoosiers all around and an airbox modification. Quote Link to comment Share on other sites More sharing options...
Spectator Racing Posted October 10, 2007 Share Posted October 10, 2007 No, his points are coming from running 315 Hoosiers all around and an airbox modification. If that's all he's done then he should be in TTS. Any tire size is permitted as long as he does not exceed the magical 8.7 wt/pwr rule. A stock C5 Z06 is about 9.3 (~3300 lbs / 355 rwhp), I don't think an airbox modification is going to add the 24 hp that will push him over the edge. Of course, as stated above, if he doesn't have a dyno sheet and someone contests him, he'll be forced to dyno at the track or bump to TTR. Actually, maybe they won't even classify him without one. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted October 10, 2007 National Staff Share Posted October 10, 2007 He needs to have a dyno sheet before competing in TTS. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted October 12, 2007 Share Posted October 12, 2007 315R compounds with no other mods will push a C5 ZO6 into TTS based on points alone. I run 295 R compunds or 315 NTO1s to keep it in TTA. So what are the approved dynos for NASA? Our '02 Z with Jake (135 pounds or so) behind the wheel was 3243 at Roebling scales two weeks ago. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted October 12, 2007 Share Posted October 12, 2007 3118lbs is the points-free minimum weight for the C5 Z06 Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted October 12, 2007 National Staff Share Posted October 12, 2007 So what are the approved dynos for NASA? Well, there's the Dynojet, and then there is the Dynojet, and don't forget about the Dynojet........ AWD's have more options only because of the lack of availability of any single brand of AWD dynamometer in all regions. However, technically, they must be legal on any that NASA has at their disposal for tech inspections. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted October 12, 2007 National Staff Share Posted October 12, 2007 3118lbs is the points-free minimum weight for the C5 Z06 Yes, but most of them will go a little under the 8.7:1 adjusted wt/hp minimum at that low of a weight (and get bumped from TTA to TTU). Quote Link to comment Share on other sites More sharing options...
