Tim Comeau 0 Posted January 17, 2008 Share Posted January 17, 2008 (edited) As a service to the 944 spec community, I'd like to come up with a spares list that people can use to help save their weekend, or that of their comrades. We can build it up and when it's done, we can copy it to the 944 spec.org website to be used as another resource for newbies. We already do an exemplary job of showing 944 spec class unity. We do this by sharing parts and by working on the cars of our competitors when they're broken down, even when it costs us a track session. It's my hope that this list will further assist in these efforts. There's going to be some things that will be excluded because they're too difficult to fix at the track or require special tools. Can it be done anyway? Yes, but it wouldn't be done under normal circumstances. Clutch? Nope. DME relay? Yes. Let's keep fluids for a separate list. We can organize it as we go. Us 944 spec moderators will keep updating the list here in the first post. We might even delete your post when we add your idea to the list in order to keep the thread efficient, so don't be offended if we do. It might be enough for a Region to have one spares box that everyone contributes to. The parts don't have to be brand new- just servicable. Ready.........Go! 1. Assorted hardware by socket size: 10mm,13mm, 17mm, 2. Extra steel lug nuts, wheel studs 3. Brake pads, brake rotors, and hardware 4. Front control arms-- steel and early and late aluminum 5. Ball joints for steel arms 6. Steering tie rods 7. DME relay 8. DME (computer) 9. Fan relays-early and late 10. Assorted fuses and bulbs 11. Radiator 12. Fuel pump 13. Fuel filter 14. Radiator hoses 15. Spark plugs 16. Fuel rail , complete. (early and late) 17. Flywheel sensors 18. Master brake cylinder 19. Clutch master and slave cylinders 20. Distributor cap and rotor 21. Alternator and new voltage regulator 22. Throttle cable,Early and late 23. O2 sensor, Early and late 24. Starter, late 25. Wheel bearings, front (87-88 have the bigger 928S bearing) 26. AFM, early 028 and late 064. 27. Throttle return spring Edited November 10, 2008 by Guest Quote Link to post Share on other sites
944-Spec#94 0 Posted January 17, 2008 Share Posted January 17, 2008 Here is my list... I don't feel like formating it for the forums, but you get the idea Type Part Description PN Condition Location Gearbox Shift Linkage Complete Used Crate in Truck Bed Gearbox Shift Linkage bolt to Gbx Used Crate in Truck Bed Driveline CV Joint Bolts 12 with Spacers Used Bin in Side Truck Shell Suspension Steel Control Arm Front New Undrilled Crate in Truck Bed Suspension Front Arm Bushing Rubber New Crate in Truck Bed Suspension Front Arm Bushing Rubber New Crate in Truck Bed Suspension Front Arm Bushing Rubber New Crate in Truck Bed Suspension Caster Block Black Welt Used Good Crate in Truck Bed Suspension Caster Block Black Welt Used Good Crate in Truck Bed Suspension Front Arm Bushing Red Welt Used Ok Crate in Truck Bed Suspension Front Arm Bushing Red Welt Used Worn Crate in Truck Bed Suspension Front Arm Bushing Red Welt Used Worn Crate in Truck Bed Suspension Front Arm Bushing Black Welt Used Ok Crate in Truck Bed Suspension Ball Joints (Steel Arms) 025.215.530.617 New Bin in Side Truck Shell Suspension Ball Joints (Steel Arms) 025.215.530.617 New Bin in Side Truck Shell Suspension Wheel Bearing Set (Front) New Bin in Side Truck Shell Brakes Master Cylinder Used Crate in Truck Bed Brakes Master Cylinder Tank Used Crate in Truck Bed Brakes Fuild Tank Cap Used Bin in Side Truck Shell Brakes Fuild Tank Cap Used Bin in Side Truck Shell Brakes Fuild Tank Cap Assmbly Stock Used Bin in Side Truck Shell Brakes Fr Brake Pads Hawk Blue 1mm Thin HB199E660 New Side Truck Shell Brakes Fr Brake Pads Hawk Blue HB199E702 None Brakes Rear Brake Pads Hawk Blue HB198E685 On Order Electric Relay Unknown 443.963.141 Used Bin in Side Truck Shell Alternator Alternator Adjuster Rod New Crate in Truck Bed Alternator Alternator Belt (for No A/C) 999.192.290.50 New Crate in Truck Bed Alternator Brushes for Altnator 0.192.052.006 New Bin in Side Truck Shell Engine Oil Pan Drain Plug Used Bin in Side Truck Shell Engine Adjuster Roler Balance shaft Used Bin in Side Truck Shell Engine Rolder Idler - front Belts Used Bin in Side Truck Shell Exhaust Exhaust Hanger Metal Used Crate in Truck Bed Exhaust Exhaust Hanger Rubber 944.111.142.00 Used Crate in Truck Bed Exhaust Exhaust Hanger Rubber 944.111.142.00 Used Crate in Truck Bed Exhaust Misc Rubber hangers Used Crate in Truck Bed Ignition Cap for Rotor Used Crate in Truck Bed Ignition 944 Plug Wires (Set 1-4) Used Crate in Truck Bed Ignition Misc Plug wires & Beru Connectors New Crate in Truck Bed Ignition Beru Crip Tool Used Crate in Truck Bed Ignition Spark Plugs - 7 new 3 used Bosch WR7DC New/Used Bin in Side Truck Shell Ignition Rotor 1234.332.333 Used Bin in Side Truck Shell Fuel Injection Air Flow Meter 83-85 0.280.202.028 Used Never opened Crate in Truck Bed Fuel Injection Throttle Body with throttle cam Used Crate in Truck Bed Fuel Injection Throttle Position Switch 0.280.120.308 Used Crate in Truck Bed (on Throttle body) Fuel Injection Throttle Body Bolts Used Crate in Truck Bed (on Throttle body) Fuel Injection Fuel Rail Early with Reg & Damper Used Crate in Truck Bed Fuel Injection Throttle Position Switch 0.280.120.308.000 New Bin in Side Truck Shell Fuel Injection Gas Cap MBZ New Bin in Side Truck Shell Fuel Injection DME Relay 944.615.227.00 Used Bin in Side Truck Shell Fuel Injection DME Relay 944.615.227.00 Used Bin in Side Truck Shell Fuel Injection Injector 0.280.150.201 Used/Old Bin in Side Truck Shell Fuel Injection DME 83-85 944.618.111.01 Used Side Truck Shell Fuel Injection DME 85.5-87 944.618.121.04 Used Side Truck Shell Fuel Injection DME 88 944.618.121.05 Used Side Truck Shell Fuel Injection Air Filter New Crate in Truck Bed Cooling Expansion tank 951 951.106.025.02 Used Crate in Truck Bed Cooling Expansion Tank Cap 140 124.500.04.06 Used Crate in Truck Bed on Tank Cooling Thermostat 80C 944.106.129.05 New Bin in Side Truck Shell Cooling Thermostat 71C (with O-rings) Used Bin in Side Truck Shell Cooling Expansion Tank Cap 140 MBZ Used Bin in Side Truck Shell Cooling Expansion Tank Cap 120 Behr Used Bin in Side Truck Shell Hose Water Pump to Radiator 944.106.237.05 New Crate in Truck Bed Hose Water Pump to Radiator 944.106.237.05 New Crate in Truck Bed Hose Water Pump to Radiator 944.106.237.05 New Crate in Truck Bed Hose Radiator to Block 944.106.239.04 New Crate in Truck Bed Hose Radiator to Block 944.106.239.04 New Crate in Truck Bed Hose Fuel Tank to Pump 944.356.557.00 New Crate in Truck Bed Hose Fuel Tank to Pump 944.356.557.00 New Crate in Truck Bed Hose Fuel Tank to Pump 944.356.557.00 New Crate in Truck Bed Hose Heater Valve Hose 944.572.383.01 Used Good Crate in Truck Bed Hose Upper Radiator to Tank 944.106.245.02 Used Spliced Crate in Truck Bed Hose Various hoses from MBZ Used Crate in Truck Bed Hose Coolant Pipe Section Used Crate in Truck Bed Wiper Wiper Arm Used Crate in Truck Bed Wiper Wiper Arm Used Crate in Truck Bed Wiper Wiper Blade Bosch Used Great Crate in Truck Bed Wiper Wiper Blade Used ok Crate in Truck Bed Wiper Wiper Blade Used Ok Crate in Truck Bed Bottles Rain X Partially used Side Truck Shell Upper Quote Link to post Share on other sites
Big Dog 0 Posted February 23, 2008 Share Posted February 23, 2008 This is a seriously helpful thread, Tim and Joe. Please consolidate it and make it a sticky as it will be a huge asset to all 944 racers. This must not get buried down in the threads or I will be forced to "bump" it over and over. Quote Link to post Share on other sites
tacovini 0 Posted February 10, 2011 Share Posted February 10, 2011 Joe?...2 wiiper arms, 3 wiper blades AND Rain-X !!?! Overachiever. -=- T Quote Link to post Share on other sites
reflexr 0 Posted August 1, 2017 Share Posted August 1, 2017 Does each region have one of these? I'm interested, because we have ditched a lot of parts that could go in to storage for the group. Tim, are you doing it for SoCal? If so I will give you all of our spares we don't take to the track. This is a great idea! Quote Link to post Share on other sites
