99HOSS Posted March 1, 2008 Posted March 1, 2008 (edited) Pictures and some stats found HERE. Basically it's been stripped of everything not needed and setup like an A/S car for a fun track day. A basic rollbar welded in & 5 pt harnesses installed on both sides. Currently under the hood is a Mr. Goodwrench 350 (back-up engine), with an SLP plenum and runners, on top of an Edelbrock 'Hi Flow' intake. Followed by a Centerforce clutch to a T-5 delivering power to a BW 9bolt differential. Also installed are: 1LE 4-wheel disc brakes with Hawks pads. Spohn custom sub-frame connectors welded in Random Tech adjustable torque arm Spohn rear lower control arms Spohn panhard bar (adjustable w/hiem joints) 3" stainless cat-back exhaust ('01 Firebird WS6) SLP stainless steel headers (Jet-Hot coated) Griffin race radiator Earls headered 4 pass oil cooler with SS braided lines ERS 850lb/" front and 175lb/" rear springs Hurst shifter .. and I'm sure a lotta other little things. Included is a spares package: L98 350 short block (perf engine) Aluminum Corvette heads T-5 trans (approx 60k miles) Aluminum driveshaft Complete 10 bolt differential Second 3rd member for the 9bolt (3:70) Stock fuel tank and radiator Complete set of 4 new rotors (front and back) Complete set of 4 rain tires on crosslaced wheels and a second set of rain tires (not mounted) ... and lastly, the 2 axle, open centered trailer that has delivered this car to the track. The full sized store box ccontains: the car's tie down straps and J-hooks the loading blocks and the portable 12v winch. $5000.00 Edited December 11, 2008 by Guest Quote
jon dawes Posted March 6, 2008 Posted March 6, 2008 Mike, Just an fyi: that link takes me to http://www.pf-flyer.com. Quote
Orkboyz Posted March 8, 2008 Posted March 8, 2008 Looks like the domain needs to be renewed. Says the name expired 28FEB. Oh yeah, Mike. Thanks for the fine instruction at the Feb NASA event. I learned a hell of alot more with you at NASA than I did at my first event with another organization. Hopefully enough people will withdraw for March and I can move up the waiting list. -Rich Quote
99HOSS Posted March 8, 2008 Author Posted March 8, 2008 Jon - yea, that's the cars website (that I forgot to renew, even after a phone call from them). Rich - Thanx for the acknowledgement. Hope to see ya there in a couple of weeks. I hope to be able to bring my car, too. Quote
99HOSS Posted March 22, 2008 Author Posted March 22, 2008 This car will be at the upcoming VIR event. The weekend of the 29th & 30th. Quote
99HOSS Posted April 12, 2008 Author Posted April 12, 2008 Car is still available. I just added a 'Hurst' shifter and new Hawk DTC60 front pads. Next outting will be Summit Pt. Quote
99HOSS Posted May 20, 2008 Author Posted May 20, 2008 This car is still available and will be in attendance at Hyperfest in a few weeks. Quote
rpob5t Posted May 30, 2008 Posted May 30, 2008 +1 for a seriously well set up 3rd gen T/A. Mike I rode in that with you at the glen about 2 years ago (I was your DE1 student with the green mini cooper S, sept/oct NASA NE event), my neck is still strained from the trips through the busstop . Easily one of the best instructors I ever had. Good luck with the sale Quote
99HOSS Posted July 8, 2008 Author Posted July 8, 2008 .. the car was a lotta fun at Hyperfest. The new pads are bedded and the 'new' shifter worked well. Next outting is VIR - full course the 25th - 27th of July. Quote
99HOSS Posted August 4, 2008 Author Posted August 4, 2008 Had a great time running the full course at VIR, but MAN, was it hot that week-end. Car is still available. Next outing is Summit Pt Aug 23 & 24. Quote
99HOSS Posted December 11, 2008 Author Posted December 11, 2008 Priced reduced. This would also be a good start for a CMC car. Quote
