Technical Bulletin: RX-7 13B--3-4-08
  • National Staff
Technical Bulletin
Mazda RX-7 13B:
1. Modification of the Variable Dynamic Intake (VDI) by removal of the actuator mechanism, and permanently wiring the VDI open will be a No-Points Modification.
2. Modification of the 5th and 6th port runners, by removal of the actuator mechanism, actuator rods, and removal of the sleeves themselves, will be a No-Points Modification. As well, removal of the actuator mechanism and actuator rods, and fixing the sleeves in the open position will also be a No-Points Modification. However, under either circumstance, if there is any filler material added, non-OEM sleeves added, modification of the OEM sleeves, or other modification to the runners, the car will need to be re-classed based on Dyno testing.
