Tommy55 Posted March 5, 2008 Posted March 5, 2008 Have looked all over the forum boards and found nothing. I changed the engine and tranny from my lt1 to an ls1 setup. I used an aftermarket aluminum clutch master and a napa clutch slave. The trans came out of the same car as the ls1. I installed a bleeder line to the slave and ran it up higher than the master cylinder to make sure i got it good and bled. My clutch will not let me shift into gears when the car is running. You have to turn it off and start it in gear. The clutch releases as soon as you lift on the pedal. Do they make a shim kit to install behind the throwout bearing and slave to get it closer to the pressure plate or do I have to make something. Anyone with info on this would be greatly appreciated. I have 1 week until our first race Thank You Tommy RM AI #55 Quote
Glenn Posted March 6, 2008 Posted March 6, 2008 Tommy, call me tomorrow. i may have what you need. free. 214-869-9603. Quote
