1987 Ford Mustang with 347, RWHP=345 TRQE=400
Vehicle Description
I am the origianl owner of this VERY NICE Mustang. The car looks and drives very well. The car is capable of Street, Strip, Road Race, here's why;
Check site;
http://cgi.ebay.com/ebaymotors/Clean-1987-Ford-Mustang-with-347-RWHP-345-TRQE-400_W0QQitemZ200204409920QQcmdZViewItem?hash=item200204409920
Drivetrain:
347 built and tuned by Paul's Automotive Engineering for $11K+
Forged crank
11:1 compresion
GT-40X heads ported
Full roller rockers
Port match to intake
Extrude hone cobra intake
Canton oil 8qt oil pan
Long tube headers
Dr Gas X-pipe
2yr old Dynamax exhaust
Aluminum flywheel
Center-force dual friction clutch
Anderson Power pipe
Pro-M 80mm Mass air meter
Griffin radiator
Engine oil cooler
30lb injectors
MSD distributor w/6AL box
Motorsport high output oil pump
Aluminum driveshaft
New T5
FMS 3.27 rear gear
Suspension & Brakes:
Brembo 4-piston front brake calipers w/13in rotor
PBR 2-piston rear brake calipers w/13in rotor
FMS rear brake adjustable valve
All wheels have 5-lug conversion w/new R58 17*9.5 SN95 cobra wheels
Front rear rear have Maximum Motorsport coil-over w/bilistein dampers
Front lower control arms have delrin bushings
Maximum Motorsports caster/camber adjustable plates. Currently set to 2 degrees negative camber
Maximum Motorsprts strut brace
Maximum Motorsports rear lower control arms
Paul's Automotive Engineering adjustable 3-link
Multimatic adjusatble panhard bar
Current weight distribution 58/42 @ 3050lbs
Maximum Motorsports rear stabilizer bar (not installed)
Maximum Motorsports 4 pt G-load (not installed)
Body:
All original with usual wear and tear for a 20yr old car.
Car has a show quality shine
Evrything but the front bumper is original
Interior:
Original interior in excellent condition
Original rear seats
Front seats were taken out of a GT in 1989
All stock and after market guages work. The center console gauges can be replaced with stock vents (included in sale)
Car has AC (doesn't work)
All power other power components work well
Rear drv lap belt missing
small hole in drivers floor
  • 3 weeks later...
Lots of bids on this car. Did you end up selling it on e-bay? Says the reserve wasn't met.
Let me know if it's still for sale!
Steve Ealy
SM-37
TTC-37
Car is still for sale. I'm lowering the price to $9100.
