jesh Posted March 16, 2008 Posted March 16, 2008 Can anyone help me wire my Longacre battery disconnect. The diagram that came with it are pretty vague and seem to be completely different than the help at 944 spec.org. So I was hoping someone that has used this with a 944 could tell me how to wire it. Thanks. Jeff Quote
JerryW Posted March 17, 2008 Posted March 17, 2008 Is this a 2 pole switch ? If so you are only going to break the circuit and be unable to prevent the alt surging. Quote
jesh Posted March 17, 2008 Author Posted March 17, 2008 No it's the 4 terminal one that is to be used with an alternator. Quote
JerryW Posted March 17, 2008 Posted March 17, 2008 What part of the instructions on the spec site won't work with your switch -- I'll try and help (I wrote the spec article). Or what on the longacre instructions is confusing -- (you'll need to type them all in (don't paraphrase) as I dont know what they say) Quote
jesh Posted March 17, 2008 Author Posted March 17, 2008 What I'm confused about is on the spec sight your instructions use the wire to the coil and the information that Longacre provides uses a wire from the alternator. You can see the Longacre instructions here: http://www.longacreracing.com/instructions/inst.asp?instid=84 I understand your instructions but don't know if I can connect my switch that way since it doesn't have a resistor. Thanks for your help. Jeff Quote
JerryW Posted March 18, 2008 Posted March 18, 2008 OK I did some reading of the Longacre instructions and a bit more research. The wire that Longacre shows as breaking the alternator connection is what you would use for the coil wire in our cars, however it does NOT allow for the surge from the alt when the switch is used. If you look at the pictures of the switch I used you'll note I have 4 small terminals not just 2. You could use the switch as is but I suggest that you return the one you have and get a 6 pole CDOC has one that has the instructions shown here http://store.cdoc.com/itemfiles/KillSwitchInstall.pdf. The one I used is like http://www.patrickmotorsports.com/part/551/ (But I really don't remember where I got mine) There is a thread on Pelican (http://forums.pelicanparts.com/showthread.php?threadid=347044) that has links to other threads on the wiring of kill switches. Quote
jesh Posted March 18, 2008 Author Posted March 18, 2008 Thanks for your help. I'll pick up another one. Quote
