Dawg Posted March 19, 2008 Posted March 19, 2008 once again the header pretty much speaks for itself. i changed my hydraboost for a manual brake system when the pedals were moved. i didn't get to drive the car much, but from what i could feel, it didn't seem that there was the same bite as the hydraboost. the confidence didn't seem to be there. i'm using a 9 to 1 pedal set up with carbotech 12's and the car weighs 3000#. the shop will go to a little smaller tilton cylinder, but the comfort level might not be there. just seeing if there is an easier set up??????????? Quote
roadracetransam Posted March 19, 2008 Posted March 19, 2008 A 9:1 pedal ratio should give you a lots of levarige. Most manual (circle track) pedals are in the 5-6:1 range. I am suprised you want to boost that. Your M/C might be way off size wise. Quote
