FS: Baer Rear Brake System, 5 Lug axle package
Baer rear disk brake COMPLETE bolt-in system (Includes PBR calipers, 12" 1-piece 5-bolt rotors, mounting brackets)
with matching Dutchman 28 spline axles for 8.8" rear-end.
$550
[email protected]
Will this fit a 94/95? And what has been the use on it?
I'm not sure about the 94/95 fit - I built this rear-end from a 93 cobra housing and used it on a fox body.
It has 1 year of street use, 1 year of autocross and 2 years of NASA HPDE/TT use.
I converted the housing to 9" ends so I don't need these parts anymore.
Paul,
A couple dumb questions....
Are the axles fox length axles or SN95 length? 5x114.3 bolt pattern? OEM diameter for use with stock-type outer bearings/seals?
Thanks,
Frank D.
Axles are fox length. Standard 5x4.5 (114.3) bolt pattern. Stock bearings and seals. Pretty straight-forward bolt-in, even includes e-brake cables.
I just looked at baer's website and could not find a good description but I do have good comparison by Baer on their package vs the Ford Racing package. Send me a PM and send you a copy.
Thanks.
