RX-7 Race Suspension for sale
1st Gen Mazda Rx-7 Suspension Components for sale
$300 - Rear Axle housing for small diameter axle shafts with Tri-link setup including panhard bar, middle tri link, braided brake lines and heim jointed aluminum toe links. Sadle for middle link is available upon request. Does not come with frame mount for panhard connection but can be supplied from G-Force.
Axles $25 each, unassembled 4.89 LSD $400, locked 3.89 diff $100.
$300 - Double adjustable Koni Dampers revalved last year by True Choice with less than 4 hours on them. Rear set. 300lb and 325lb springs available for $20 each.
$500 - Single adjustable Koni Dampers revalved last year by True Choice with less than 4 hours on them. Front Set with G-Force Roll center turn in spacers mounted on bottom. 450lb and 500lb springs avialable for $25 each.
Valving plots available for both sets of dampers
http://www.gforceengineering.net/products.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
$500 Massive custom Front brake setup - Willwood Powerlite 4 piston quick change calipers, H compound pads, brake duct tube, 11 inch rotors, braided lines and aluminum spacer which will allow use of Diamond 13" wheels.
Email for lots of pictures. [email protected] or 540-230-9047
located in Charlotte, NC
Co-drove this car w/ this exact setup as well as it's previous 3 suspension setups and this was the best. Extremely fast, but more importantly, very predictable and forgiving.
Can't say enough good things about the brakes. Typical weak point for this car, we could run no problem flat out and never worry about the brakes. Pads lasted longer than the OE setup by far as well.
  • 10 months later...
