**SOLD** 1995 Mustang Cobra Track Car $10,800
Well, with a 6-month old in the house now I’m going to have to make some sacrifices. Selling my ’95 Cobra and ending my hopes for American Iron is one of them. This car is in EXCELLENT shape; almost unbelievable for a car that has been doing HPDE3’s for the past couple of years with NASA SE & MA, various Mustang Clubs, and Turn One Motorsports. The car has never been wrecked and the body is straight and near perfect. The car was built referencing NASA American Iron rules and would be an excellent platform for a competitive car.
1995 Mustang Cobra (non-street legal)
113,092 Miles
VIN- 1FALP42D7SF199649
I have clean title in hand.
Chassis:
Car has been fully gutted, including doors, rear deck lid, dash, sound deadening material, A/C, smog pump, extra pulleys, etc.
New exterior paint in original Ford Factory white color
Vehicle weight is 2,974 lbs. w/o driver or fuel
MM XL Full-Length subframe connectors
K-member brace
Front and rear tow hooks
Master Kill Switch located on dash, left of steering wheel
Fire extinguisher mounted in floorboard behind passenger seat
Strut tower brace
Lexan rear quarter windows w/ NACA duct in driver’s side
Custom spoiler mounted on rear deck lid
Custom removable front spoiler mounted w/ Dzus fasteners under front bumper
Custom vents installed on factory Cobra fiberglass hood
Hood and deck lid secure with quick release pins
50 lbs. Ballast mounted in passenger side of trunk along with battery in aluminum box
Window net on driver’s side
Interior:
New interior paint- white
Custom built 6-point .095” x 1.75” DOM with NASCAR bars on driver’s side, X-bars on passenger side, plated and/or boxed mounting points, 1-piece diagonal cross brace, rear down bars attach at rear shock towers
Cage was built by Dan Robson who has 25 years racing experience & has been running GT5/GTL in SCCA going to the Runoffs numerous years. He fabricates his own GTL chassis’s from the ground up.
Corbeau Forza Racing seats- Driver and passenger
RCI harness in driver seat
G-Force harness in passenger seat
Grant Formula steering wheel w/ splined quick release
Custom dash center console w/ Autometer Ultralite Oil temp and Coolant temp gauges, wiper, and light toggle switch
Suspension:
MM Caster/Camber plates
Bilstein HD front shocks (ones that had factory wrap around mounting ears)
Bilstein MM Sport valve rear shocks
MM front (COP-1) and rear (COP-3) coilover kit 375 lb. Front/ 250 lb. Rear springs
MM rear lower control arms
HPM Panhard bar
Eibach rear sway bar
Brakes:
Cobra PBR brake calipers front 13” and rear 11.65” (freshly rebuilt front calipers)
Brembo plain one-piece rotors
Stainless steel brakes lines
Carbotech XP10 front brake pads
Hawk HPS rear brake pads
Custom front brake cooling ducts which direct air to the center of the rotor, not the face
3” cooling ducting
Motul 600 brake fluid
Wheels/Tires:
1 set- Ford 95 Cobra R wheels 17x9 with Hoosier R6’s 275/40/17 w/ 70% life
1 set- Ford 95 Cobra R wheels 17x9 with Kumho MX 275/40/17 w/ 40% tread but have a lot of heat cycles
Motor:
Original Cobra Motor with Cobra upper/lower intake manifold and GT-40 heads
Mac’s Full-length headers
H-pipe, no-cats
Flowmaster mufflers that dump
Fluidyne aluminum radiator
“Boxed” radiator area
Underdrive pulleys
BBK Cold air intake w/ fenderwell mounted K&N filter
Pro-M mass air meter
Mobil-1 Synthetic oil w/ Pure-One filter
Factory Cobra oil cooler
Ford Racing harmonic balancer
Kirban adjustable fuel pressure regulator
Adjustable clutch quadrant
Dyno:
Readings are from a DynoJet dyno roughly 2,000 miles ago:
250 HP & 298 ft.-lbs. Torque
I will provide a copy of the dyno sheet.
Driveline:
T-5 5 speed manual
3.27 Rear gear
T/A diff. cover
Drive shaft safety loop
Steeda Tri-Ax shifter
Custom shift lever extension and layback
Simpson Nomex shifter boot
Price includes extras such as car cover, extra set of Brembo front rotors, extra brake pads, ignition coil, etc.
Price: $10,800 or would consider trade for a 1995-1998 BMW E36 M3
I can be reached at 864 590-6456 or daniel (at) classiccoachsc (dot) com
Please email me if you would like more pictures. Car is located in Spartanburg, SC 29303.
Thanks, Daniel Cox
47b8dd07b3127cceb6e93131ca6b00000020100BbsXLlozZsa
47b8dd07b3127cceb6e9313bca6100000020100BbsXLlozZsa
47b8dd07b3127cceb6e931384b5200000020100BbsXLlozZsa
47b8dd07b3127cceb6e95f534b0e00000020100BbsXLlozZsa
