marksti Posted January 12, 2009 Posted January 12, 2009 (edited) Car: 06 Mustang GT... VERY CLEAN 17,961 miles Suspension: Griggs Torque arm kit complete Griggs rear control arms Griggs Watts link (race) Griggs/Koni coilover suspension with rear coil over conversion Suspension installed/tuned at Griggs Racing within the last 2 months. Ford racing front sway bar Steeda front sway bar support Steeda g brace Steeda bumpsteer kit BMR LCA relocation brackets for LCAs BMR gen 3 front lower control arms Ford racing front strut brace Engine: Comp cams stage 2 cams Steeda complete cold air intake Steeda throttle delete plates Ford racing x pipe SLP exhuast Custom X-cal 3 tuner/tunes Steeda pullies Ford racing radiator Gt500 throttle body kit(not installed yet) Brakes: DBA front and rear rotors Heat coated brake calipers Hawk pads front and rear Stainless lines Agent 47/Steeda brake cooling kit ATE blue fiuld Aero: VIS carbon "heat extractor" hood Steeda carbon front splitter Steeda mid wing Agent 47 mirrors Drivetrain: Spec stage 2+ clutch Spec lightweight flywheel Coast light weight driveline Steeda Tri Ax shifter Wheels: Wed Sport 18's (18#'s) Nitto 275 40 18 NT01s (50% remaining) Track tires with spare set of BFG G force KD's ( 80% remaining) Interior: Corbeau FX pro seats with daul locking sliders Auometer new style shift light/tach Steeda shifter handle/ball CG locks Weight mods: No AC with belt idler installed No wipers/motor Light weight battery (9#'s) Light weight bumper beams front and rear All fiulds are Redline This is a low option car that is as light as they come, It toke me a while to find a this car new without leather/power interior/side bads or the heavy MACH sound system. Car weighs in at 3200 #'s With full tank of fuel/full interior. Dynos at 349 RWHP/355TRQ Car is corner weighed and suspension setup by one of the best Mustang suspension tuners in the country. I have ALL the factory parts and the car can be returned to a daily driver or stock. PM or email at [email protected] if serious Thanks Edited January 12, 2009 by Guest Quote
