KenAEM Posted January 15, 2009 Posted January 15, 2009 AEM is selling their RSX race car asking price $15,000. Please contact Ken at [email protected] or 310-484-2322 Ext 212 Full Roll cage to NASA's Saftey spec, There is log books and annual tech Suspension Front Shock JIC Custom Race Front Springs 17KG / 899 lbs. Front Sway Bar Stock RSX Type-S Front Sway Bar Rate 290 lbs. Front Camber -4 Degree Front Toe 0 mm Front Compliance Bushings Stock RSX Type-S Front Lower Control Arm Bushings Stock RSX Type-S Front Lower Ball Joints Stock RSX Type-S Rear Shock JIC Custom Race Rear Springs 24KG / 1348 lbs. Rear Sway Bar ASR Rear Sway Bar Rate 757 lbs. Rear Camber -3.8 Degree Rear Toe 0 mm Rear Lower Control Arms Stock RSX Type-S Rear Lower Control Arm Bushing Stock RSX Type-S Steering Bushing Stock RSX Type-S Wheels, Tires & Brakes Motegi Trak Lite 16x7 PN # 23886765 Wheels ARP Wheel Studs 85 LBS Lugnut Torque Mackin Lugnuts Front Tires RA-1 245/45-16 Front Tire Pressure Rear Tires RA-1 245/45-16 Rear Tire Pressure Front Brake Rotors Stock Brake Pads Front Hawk HT-10 Rear Brake Rotors Stock Rear Hawk Blue Engine K20 Engine AEM Cold Air Intake DC Sports Race Header Header Custom with Turn Down Exhaust conventional 10-30 Engine Oil Honda MTF Transmission oil Honda Steering Fluid Power Steering Fluid NAPA 060557 Alternator belt Transmission Stock RSX Type-S Transmission Mugen Diff 1st 2nd 3rd 4th 5th 6th Final ACT Full face Clutch ACT Pro Light Flywheel EMS/Data 30-1030U EMS AIM MXL Pista Data Acquisition Weight/Ballast 2710 Weight with driver Front Left Front Right Rear Left Rear Right 35 lbs. each Big Bars 20 lbs. Small Bar Quote
savowood Posted February 11, 2009 Posted February 11, 2009 What's the chance of this car passing a state inspection for street use? I'd be interested in racing it, but also driving it to the track. -Michael Quote
