rbrumm Posted January 23, 2009 Share Posted January 23, 2009 All: just need a little help on what GTS class my car would run in I have a 70 prosche 911 the previous owner tells me that the horse power is +-220 and the car weighs +- 2300 lbs the tires that are on the car are Hoosiers DOT P315/35/zr17 rears & Hoosiers DOT P245/40/zr17 fronts I plan to have the car dyno'ed & weighed soon but I just needed some thoughts on the class Thanks Rick #91 2009 Rookie Quote Link to comment Share on other sites More sharing options...
ianacole Posted January 23, 2009 Share Posted January 23, 2009 Assuming TQ is less than HP, you're at 10.45/1, which is at the bottom end of GTS-4. I'd recommend adding a bit of weight or removing some power to get to 11/1 (top of GTS-3), or remove weight or add power to move up in GTS-4. But, before making any drastic changes, I'd see what the dyno says first. Oh, and welcome aboard! Quote Link to comment Share on other sites More sharing options...
rbrumm Posted January 23, 2009 Author Share Posted January 23, 2009 Thanks for the info. Rick Quote Link to comment Share on other sites More sharing options...
Jim Child Posted January 23, 2009 Share Posted January 23, 2009 I have a 70 prosche 911 the previous owner tells me that the horse power is +-220 and the car weighs +- 2300 lbs Don't forget that class is determined by what the car weighs WITH the driver divided by the HP. Quote Link to comment Share on other sites More sharing options...
rbrumm Posted January 23, 2009 Author Share Posted January 23, 2009 add 200 lbs to the car Thanks Rick Quote Link to comment Share on other sites More sharing options...
ianacole Posted January 23, 2009 Share Posted January 23, 2009 add 200 lbs to the car Thanks Rick Well, that puts your ratio at 11.36, which is good for GTS-3. Quote Link to comment Share on other sites More sharing options...
rbrumm Posted January 24, 2009 Author Share Posted January 24, 2009 thanks Rick #91 Quote Link to comment Share on other sites More sharing options...
