stevepoe Posted February 4, 2009 Posted February 4, 2009 SOLD . tfs-51500002 track heat intake "silver" used but still in great shape. $350 plus shipping. The Trick Flow track heat manifold also has a 75mm throttle body inlet diameter and is designed for 1500-6500rpm operation in a 302. This manifold works great on n/a 302 motors that are making peak hp in the 6000rpm area, utilizing good heads and a moderately sized cam. The lower intake runners are sized to a 1250 fel-pro intake gasket (1.2"x2.0") just as the street intake, but the runners are shorter in the upper intake to allow upper rpm breathing. This intake will also work great on stroker 331-347 motors that are built for upper 5000rpm horsepower peaks. also 4/sale is a track heat 1" spacer kit tfs-51520008 $30.00 [email protected] Cincinnati Ohio Quote
