Rosiecki Posted February 7, 2009 Posted February 7, 2009 BMW E46 M3 RACECAR FOR SALE! This racecar was built in 2007 and has only been maintained by Patrick BMW and Fall-line Motorsports – www.fall-linemotorsports.com. It was primarily used for N.A.S.A GTS Challenge and Driving Schools. In 2008 it had 7 starts and 7 wins, won a 2008 N.A.S.A GTS4 National Championship at Mid-Ohio, and holds 3 track records in NASA/SCCA. This car has no fancy custom parts; the car is extremely fast and reliable. Doubt you will ever find a better built E46 M3 Racecar for this price! This car is being priced to sell now! -E-mail [email protected] for detailed pictures. -Visit www.ryanosiecki.com for videos. -Fast Facts- -This is race ready car! -Transmission recently replaced with Brand New OEM Part in beginning of 2008. -New Lightweight Flywheel installed with Brand New Parts in beginning of 2008. -Brand new clutch discs and spring just installed, Never Used. -Differential has only 3 weekends on it. -Spherical bearings throughout. -Weight – 2,800lbs w/o driver. -Dyno Jet Results – 316 RWHP – 250 RWTRQ. (Have Dyno Sheet from 2008 NASA Nationals) -Original Chassis - never wrecked - never needed body work. -Very well built NASA GTS4 / BMWCCA CM car. -Has log book for SCCA/NASA. The car exceeds all safety requirements with the best equipment installed. -Lap Times- -Elkhart Lake, WI, Road America – 2:26.1 -Joliet, IL, Autobahn South Track – 1:31.9 -Joliet, IL, Autobahn Full Track – 2:34.1 -New Lexington, OH, Mid-Ohio Pro – 1:31.9 -New Lexington, OH, Mid-Ohio Club - 1:34.6 -IF YOU WOULD BUILD THIS CAR IT WILL COST over $115,000! -YOUR CHANCE TO GET A PROVEN RACE CAR THAT IS READY TO RACE IN SLOW ECONOMIC TIMES FOR $59,500! THIS IS WHAT CAN BE YOURS TODAY: BODY, INTERIOR, AND CHASSIS $10,500-CUSTOM 1 ¾ CHROMOLY CAGE BUILT BY FALL-LINE MOTORSPORTS, NASCAR BARS ON BOTH SIDES, SUB-FRAME RE-ENFORCEMENTS, SHOCK TOWER SUPPORTS IN REAR, A&B PILLAR GUSSETS, CAGE PAINT $2,350-FIBERGLASS HOOD, DOORS, AND DECKLID – MADE BY MA SHAW $1,900-BIMMERWORLD CARBON RACEWING $1,500-RECARO SPG PRO RACER SEAT $1,000-CENTER JACK POINTS $900-RECARO POLE POSITION SPG SEAT $850-AMD DIRECT WIRE TRANSPONDER AND DISPLAY $650-SCHROTH PROFI III BLACK 6PT P/U BOLT LAP $600-TEGRIS SPLITTER UNDERTRAY – SAME MATERIAL USED ON NASCAR CUP CARS $500-SAFECRAFT 5LB 1301 FIRE SUPPRESION SYSTEM WITH CLAMPS $500-MOMO HUB ADAPTER WITH QUICK DISCONNECT $400-VAC BILLET ALUMINUM E36/E46 FLOOR MOUNT $350-PLASTIC SIDE WINDOWS INSERTS $350- E46 SOLID REAR SUBFRAME MOUNT KIT $350-BLACK ANODIZED PANEL TO REPLACE REAR SEAT BACK $350-FALL-LINE 3-PIECE CARBON DASH $250-RECARO BRACKETS $250-FALL-LINE CARBON FIBER DRIVER SIDE FLOORPAN $220-MOMO 350 MM BLK SUEDE 3 SPOKE STEERING WHEEL $200-BLACK ANODIZED PANEL TO REPLACE LOWER SEAT BACK $200- WINDOW NET $200- DRIVERS RIGHT NET $150- TOW HOOKS $150-RECARO SLIDERS $150- E46 SOLID DIFF MOUNT KIT $120- 14” LONGACRE MIRROR WITH BRACKETS $100-ROLL BAR PADDING $40- OMP BLUE ALUMINUM QUICK-RELEASE BONNET PIN KIT $40-OMP STAINLESS STEEL SPRING CLIP LATCH KIT $23,920 TOTAL BRAKES AND WHEELS $3,300- BREMBO 4 PISTON 14.0” GT- FRONT ($700 Value Rotors have 1 weekend on them) $2,800- BREMBO 4 PISTON 13.6” GT- REAR $1,800- SSR COMPETION – 18’x 9.5’ (Comes with used Hoosier Wets 275-35-18 Tires Alone $1200 new) $1,800- SSR COMPETION – 18’x 9.5’ (Comes with used Pirelli Racing Slicks 265-35-18 Tires $1500 new) $30- E46 CARBON ROTOR BACKING PLATES $225- E46 M3 CARBON BUMPER DUCTS $190- TC KLINE PRO WHEEL STUDS $75- 3” SILICON DUCT HOSE $10,520 TOTAL MOTOR AND DRIVE LINE $3,600-DIFFSONLINE VARIABLE RAMP 3 CLUTCH CUSTOM DIFF W/ 4.10 GEARSET $2,500-FALL-LINE MOTOSPORTS CUSTOM DIFF/TRANS COOLERS $2,300-AIM MXL PISTA DATA ACQUISITION SYSTEM $2,400-SUPERSPRINT STEPPTED HEADERS $2,150-DINAN CAMSHAFTS $1,900-JB RACING ULTRALITE FLYWHEEL W/ 5.5” TWIN DISC CLUTCH (Brand new clutch discs/never used) $1,500-CUSTOM 3” EXHAUST $1,400-DINAN COLD AIR INTAKE & MASS AIR $1,300-DINAN THROTTLE BODIES $1,000-2ND FUEL PUMP SO IT WILL NOT HAVE STARVATION ON THOSE RIGHT HANDERS $900-DUAL PASS 3 ROW SS PLATE OIL HEAT EXCHANGER $500-CUSTOM DME TUNED FOR 100+ OCATANE FROM OSCAR VELEZ (Octane level can be changed) $400- AIM LAMBDA CONTOLLER KIT WITH SENSOR $325-FALL-LINE MOTORSPORTS UNDERDRIVE PULLEYS KIT $250-VAC MOTORSPORTS SOLID ENGINE & TRANSMISSION MOUNTS $150- SPAL 16” CURVED ELECTRIC FAN $130-AIM USB B-FEMALE CABLE WITH MOUNT AUTOSPORT $100 AIM OIL PRESSURE SENSOR $100-AIM CUSTOM WHEEL SPEED SENSOR $100 AIM FUEL LEVEL SENSOR $23,005 TOTAL SUSPENSION AND STEERING $3,400- MOTON CLUBSPORT 2 WAY DAMPERS (REAR COILOVER) $1,000- SHOCK REBUILD BY PERFORMANCE SHOCK INC. ONLY 1 WEEKEND ON REBUILD $750-CUSTOM RRT RACING CONTROL ARM, OFFSET CUP, 1" SPACER $600-GROUND CONTROL SWAYBARS $550-TCKLINE CAMBER/CASTOR PLATES $500-TCKLINE REAR LOWER CONTROL ARMS $350-TC KLINE E46 ALL TRAILING ARM MONO BALL KIT $300-E46 SPORT TIE RODS $200- REAR DOUBLE SHARE BRACKET $135- HYPERCOIL 4” TALL x 2.25” 750LB $135- HYPERCOIL 8” TALL x 2.25” 325LB $60- HYERCOIL 2.25” HELPER SPRING GUIDE $50- HYPERCOIL 2.25” HELPER SPRING $8,080 TOTAL MISCLENOUS $30,000- 300 hours of Labor/Tuning $20,000- Current Cost of a 2001 E46 M3 $50,000 TOTAL -IF YOU WANT TO BUILD THIS CAR IT WILL COST $115,525! -GET A FAST CAR IN SLOW ECONOMIC TIMES FOR $59,500! Quote
