ScottH Posted February 16, 2009 Share Posted February 16, 2009 (edited) 1987 Mustang Notchback SCCA American Sedan (AS) legal WHRRI & SCCA logbooks, both clean. Very reliable car. Good competitive Regional car $9,500 for car and spares, including brand new Edelbrock Performer aluminum cylinder heads (complete) $13,000 for car, trailer and spares 2004 Cargo Express 20’ enclosed trailer If car sells first, trailer price is $4,000. See photos: Contact Scott 248-701-4181 [email protected] Engine/Trans Performer RPM Intake manifold (Part # 7121), Holley 600 Double Pumper Carb (Part # 4776), 14”x 3” K&N air filter,7qt Canton Road Race oil pan, Melling High Volume Oil Pump, Perma-Cool engine oil cooler, Ford Motorsport Long Tube Headers – 1-5/8” diameter tubes, Dynomax Bullet mufflers, Dr. Gas X-pipe, Racer Walsh AS500 mechanical camshaft & lifters, Ford Motorsport valve springs & pushrods, Trick Flow 1.6 roller rockers, ISKY guide plates Ford Motorsport rocker studs, Complete MSD ignition system, Holley Red fuel pump & regulator, Aeromotive fuel filter, Macleod SFI bellhousing, Ford Motorsport King Cobra clutch disc & pressure plate, Powermaster one wire 100 amp alternator, Energy Suspension Engine/Trans mounts T5 trans/B&M Ripper shifter, Ford Motorsport Mustang Cobra radiator, Electric cooling fan, March underdrive pulleys Ignition/Fuel Complete MSD ignition, Holley Red fuel pump & regulator, All steel braided fuel line, ATL 22 gallon fuel cell, Aeromotive fuel filter Brakes Front – Baer Sport – 12” rotors – 4 lug, Rear – Baer Touring – 12” rotors – 4 lug, Tilton adjustable proportioning valve, Steel braided brake hoses Front Suspension/Chassis/Steering QA-1 single adjustable struts, Steeda 1000lb springs, Ford Motorsport Del-alum control arm bushings,1 1/8” front sway bar - stock Steeda Sway bar bushings, Steeda bumpsteer kit, Maximum Motorsport Cast/Camber plates, Sub-frame connectors, Ford Motorsport Strut tower brace, New steering rack, pump & cooler in 2008. Rear Suspension/Axle QA-1 single adjustable shocks, Steeda 350lb springs, Steeda weight jackers, Steeda control arm bushings, Custom 5 –link rear suspension w/adjustable panhard bar (Similar design to the Steeda 5-link, but with custom upper links) 25 mm Rear sway bar, Ford 8.8 housing, Moser 31-spline axles, Motive Gear 3.90 ring & pinion, Detroit Locker Differential. Safety Equipment 8 point roll cage w/NASCAR door bars, Corbeau Forza racing seat G-Force 5-point camlock harness (Good until 2010), SafeCraft fire suppression system, RJS window net, Battery cut-off switch, ATL 22 gallon fuel cell Gauges & Accessories Full AutoMeter Gauges Water & oil temp, oil pressure, fuel pressure, volts, tach, Hot Laps In-Car timer, Moroso switches & switch panel, Longacre 4 panel wink mirror, Moroso battery box, IO Port in-car camera mount, AMB timing transponder Tires & Wheels 16x8 ROH Snyper wheels (3 sets), 16X8 set of wheels with rains, 275-45-16 Hoosier tires (1 newer set, 3 heat cycles), 245-55-16 Hoosier Dirt Stocker Rain tires (used once) Spares Front rotors, Stock bellhousing, Rear calipers (2), Brake hoses, 2 doors, Brand new, never on car Steeda rear upper links and axle brackets, Spare stock 302 complete (needs freshening), Stock shifter, Brand new in box Edelbrock Performer RPM aluminum cylinder heads. These are complete heads that just became legal in American Sedan as of 11/1/08. Trailer 2004 Cargo Express STE Touring Edition 20’ enclosed White in color, brakes on both axles, 3500lb axles, beavertail, 96” wide, front cabinets, front workbench, Pitpal door organizer, floor jack holder, rubber mat on entire floor, painted plywood walls, 12v lighting, dual roof vents Edited June 24, 2010 by Guest Quote Link to comment Share on other sites More sharing options...
Sidney Posted February 16, 2009 Share Posted February 16, 2009 Scott, May I offer some advise that may help sell your car over here. For starters, an American Sedan car is kind of a 'tweener here in NASA. The body, wheels, transmission and brakes are closer to CMC but the engine is more American Iron. The Hoosiers are basically trade material as the Toyo R888 is the spec tire in both AI and CMC so their value is limited. Also both classes are ruled by strick Power to Weight Ratios. You need to get your car over to your nearest Dynojet 248 for some numbers. I'd suggest offering the car minus the engine for the CMC crowd. Good luck with your sale, Sidney Franklin Bloomington, IL CMC #64 Quote Link to comment Share on other sites More sharing options...
King Matt Posted February 16, 2009 Share Posted February 16, 2009 The adjustable panhard and 5-link is not legal in CMC either, but I agree with Sidney. It's a 'tweener. That's a tough sell. If the rear suspension can be retrofitted back to the stock 4-link, it could fit into CMC or CMC-2 with a few engine mods (cam, headers, and probably heads). Quote Link to comment Share on other sites More sharing options...
ScottH Posted February 16, 2009 Author Share Posted February 16, 2009 Thanks for the advice. I may just get it to a dyno and get some numbers. I'm just throwing this ad on every racing site that might be interested in a road race Mustang or any Mustang period. Hopefully I find a person that happens to be looking for this car. Thanks again. Scott Quote Link to comment Share on other sites More sharing options...
1BAD88 Posted February 16, 2009 Share Posted February 16, 2009 Can i get more pics to [email protected] Thanks Kyle Quote Link to comment Share on other sites More sharing options...
ScottH Posted February 16, 2009 Author Share Posted February 16, 2009 Can i get more pics to [email protected] Thanks Kyle Pics sent. Scott Quote Link to comment Share on other sites More sharing options...
ScottH Posted February 20, 2009 Author Share Posted February 20, 2009 Slight edit to price. Scott Quote Link to comment Share on other sites More sharing options...
ScottH Posted March 10, 2009 Author Share Posted March 10, 2009 Car is still for sale. Link to more pics. http://s559.photobucket.com/albums/ss38/as69scott/ Quote Link to comment Share on other sites More sharing options...
ScottH Posted April 20, 2009 Author Share Posted April 20, 2009 Still for sale. Quote Link to comment Share on other sites More sharing options...
ScottH Posted May 11, 2009 Author Share Posted May 11, 2009 Still for sale. Will be posted here until sold. Quote Link to comment Share on other sites More sharing options...
ScottH Posted June 11, 2009 Author Share Posted June 11, 2009 Still for sale. Lets talk. Quote Link to comment Share on other sites More sharing options...
ScottH Posted July 2, 2009 Author Share Posted July 2, 2009 $12K takes it all. Car spares and trailer. Quote Link to comment Share on other sites More sharing options...
fadatec Posted July 27, 2009 Share Posted July 27, 2009 Hello Scott is the Mustang still for Sale.....I'm in Miami Fl. Quote Link to comment Share on other sites More sharing options...
ScottH Posted July 27, 2009 Author Share Posted July 27, 2009 Still for sale. I'm in Michigan. See pics here. http://s559.photobucket.com/albums/ss38/as69scott/ Quote Link to comment Share on other sites More sharing options...
fadatec Posted August 5, 2009 Share Posted August 5, 2009 Hey Thanks I talked to the son but he wants a Spec Miata....don't know.... Quote Link to comment Share on other sites More sharing options...
ScottH Posted August 7, 2009 Author Share Posted August 7, 2009 Hey Thanks I talked to the son but he wants a Spec Miata....don't know.... No problem. Thats's a bit easier on the budget. Quote Link to comment Share on other sites More sharing options...
ScottH Posted August 7, 2009 Author Share Posted August 7, 2009 New price $9500 for car and spares, including brand new in the box Edelbrock aluminum heads $13,000 for the car, spares and trailer Quote Link to comment Share on other sites More sharing options...
ScottH Posted October 20, 2009 Author Share Posted October 20, 2009 Still for sale. Quote Link to comment Share on other sites More sharing options...
ScottH Posted November 20, 2009 Author Share Posted November 20, 2009 Still for sale. Make a reasonable offer and go racing next year. Quote Link to comment Share on other sites More sharing options...
ScottH Posted January 28, 2010 Author Share Posted January 28, 2010 Aluminum heads are sold. Car is still for sale. $8500 firm. Quote Link to comment Share on other sites More sharing options...
ScottH Posted March 17, 2010 Author Share Posted March 17, 2010 Still for sale. This car is A-Sedan legal but could be AI or AIX. This car is straight and clean. Not a better ready to race car for this kind of money. $8500 for the car and spares. $12,000 for car, spares and trailer. Call Scott 248-701-4181 [email protected] Quote Link to comment Share on other sites More sharing options...
ScottH Posted June 24, 2010 Author Share Posted June 24, 2010 SOLD! Thanks for looking Quote Link to comment Share on other sites More sharing options...
