Another 944 Cup Car Under $7k
Here is another car ready for the 944 Cup series. $6500. Located in the DC area. 1989 with 2.5L engine that has zero hour fresh head and rod bearings, belts and rollers, and water pump. Koni sport shocks with ride height adj. frt perches. Also, adjust. camber plates, 29 mm frt sway and 22 mm rear sway, upgraded springs and torsion bars. Comes with Turbo brakes frt and rear. Cone filter.
NASA log book, Sparco race seat, 5 pt harness good thru 2011. To get thru 2009 tech, just need window net and right side net.
Email me at [email protected]
  • 2 weeks later...
I am interested! More details? I am in North Carolina and am in HPDE @ NASA Mid-Atlantic (VIR). Looking for a track car that I can continue to learn with and maybe move in the Spec 944 if I decide to race. Right now just into having fun.
Pictures?
The car sold yesterday.
Have another that 944 Cup car that will post later today or tomorrow. Same price range, great looking car that is well equipped, but not a spec candidate.
I admit that I am new to this but I must ask why is it not a Spec car candidate?
It is not a Spec car candidate as only 2.5 8v cars are allowed in the Spec series (basically '83 - '88 8v n/a 944s only and 87-88 924S only).
The '89 n/a 944 8v is a 2.7 liter motor so more powerful but Cup series has a wider allowance for 944s which the '89 can run in. You could always sell the 2.7 motor and by a 2.5 8v on the cheap and be legal for both Spec and Cup. Guys looking to build big turbo 944s will pay for a 2.7 motor especially the head as it has bigger valves allowing more CFM through.
Of course as I progress through HPDE and maybe stay at 3 or TT, it is of no concern. It looks to me like purchasing that kind of car, I have a whole range of options and if I decide to compete, I can go Cup as is, or Spec with an engine change or I could add a large turbo to that platform. Have I understood correctly? Thank you for the help as I am trying to learn a bit here.
Well not exactly. To run in 944 Spec you would have to remove the ABS brakes that all 1989 944 na's came with. Check the cage as the 944 Spec rules are much more restrictive than Cup on this. No you can't just bolt on a turbo to run in Super Cup. Besides the legalities the compression would be way too high for the engine.
This car sounds like a very good price and would work well for your intended purposes. It was built for 944 Cup and only if you decided to run a different class would you need to change it. Good luck and have fun.
