Toyo 235/50/15 Tire clear on Civic EG?
Hi,
I was just wondering if anyone has tried tthis tire on a civic. I have read and seen people who fit hte 225 50 or 45 15 in civic.
Also what size rim and offset would be needed for either 225 or 235?
Thanks
they will be a tight fit, but you could probably make them work. Our 225/45 fit no problem. The 225/50 and 235/50 are much taller. You might need to run spacers so it doesnt run the trailing arm.
The 235's are HUGE, good luck fitting them without fully flared fenders.
Hi,
Thanks
I tried them on my DC. They don't safely fit on the rear. They would rub on the trailing arm and fender. not to mention its very questionable for the rule :
7.12 Wheels and Tires
c) Track width may be changed by use of spacers or wheel offset, but the top one-third (1/3) of the
tire may not protrude outside of the fender when viewed from above. Example: If your tire
measures twenty-seven (27) inches in diameter, the top nine (9) inches of the tire may NOT
Camber, Camber, Camber. EDO ran 245/40/16 in H4 last year on his DA
245/45R16 I think...
Did you have the fender lip rolled? What offset and wheel width did you have?
Thanks
Thanks
The fender lip was rolled not just used a baseball bat method, it is rolled perfectly flat. I believe I was using a 38 offset wheel and had to use either a 5 or 8mm spacer to prevent the tire from rubbing on the trailing arm under load. With the 8mm spacer it only lightly rubbed on the ta but now rubs on fender and rear bumper.
I just noticed last night the front rubbed on the body of the car before the suspension bottomed out.
235/50/15 on the front and 205/50/15 on the rear....
JDM yO!!!!!!
JDM yO!!!!!!
Is that the set up on your hatch? Do you mind sharing the offset on your wheels?
You could probably go 225 on the rear, but you might be using 205 because of your specific set up.
Thanks
sorry, no that's not what i am running. The 235s are just too expesive, too heavy, and too tall for me to spend ~$225 dollars each to give it a test fit.
i agree.. they are way too tall and heavy. i think the 225/45 or 225/50 is the way to go.
I spent the money for you
that was awfully nice of you
if you want a set i have a new set of 235?
/50/15
will sell it cheap.
benny
