deadeyeb Posted March 30, 2009 Posted March 30, 2009 (edited) I need an engine block for a 83 n/a 944, does anybody know of any located on the northeast coast. I'm located in MA. southcoast. Did a pressure test didn't like cylinder 4 tore apart and found this mess. Edited March 30, 2009 by Guest Quote
deadeyeb Posted March 30, 2009 Author Posted March 30, 2009 how come i can't post a pic .what does it mean when it says quota has been filled Quote
ianacole Posted March 30, 2009 Posted March 30, 2009 Try going to http://tinypic.com" onclick="window.open(this.href);return false;, uploading a picture there, and then copying the image code that it supplies once uploaded...it'll be text bracketed by "". Paste this into your post and you should be golden Quote
deadeyeb Posted March 30, 2009 Author Posted March 30, 2009 thanks for the pic help. i keep forgeting to use photobucket. Quote
APartAbove Posted March 30, 2009 Posted March 30, 2009 I have a clean block from an '84 with no grooves in the walls. I'm looking to get $250 for it. Email me at [email protected] or call me at (440) 666-0350. Quote
944-Spec#94 Posted March 30, 2009 Posted March 30, 2009 I have a clean block from an '84 with no grooves in the walls. I'm looking to get $250 for it. Email me at [email protected] or call me at (440) 666-0350. Not bad. If you do buy does that include pistons? If not make sure you match the tolerance groups 0, 1 or rarely 2. These numbers are stamped on the piston tops and on the top of the block. Quote
Sterling Doc Posted March 30, 2009 Posted March 30, 2009 Good deal! John (runs A part Above) is a new 944 Spec Midwest sponsor as well! Quote
APartAbove Posted April 1, 2009 Posted April 1, 2009 If you do buy does that include pistons? If not make sure you match the tolerance groups 0, 1 or rarely 2. These numbers are stamped on the piston tops and on the top of the block. In this case the pistons are going with the block. I sold the whole short block of this engine. Other times it's just the block, girdle, balance shafts/covers with all the nuts/bolts for the girdle. All depends on how motivated I am on any given day. Thanks guys. John A Part Above (440) 666-0350 http://www.apartabove.com" onclick="window.open(this.href);return false; Quote
Tim Comeau Posted April 1, 2009 Posted April 1, 2009 Fred, Sounds like a good deal, but I'd first make sure you actually need a new block. I've seen some pretty good scoring that I thought would be the end of a block, but the machine shop told me it shouldn't be a problem! Quote
deadeyeb Posted April 2, 2009 Author Posted April 2, 2009 pulled pistons found bent rod and scortched piston on #4 . block is going into hibernation right know . are all rod journals crossed drilled on these blocks? how about the mains? talking with john at apart above for a short block. thanks for the replies Quote
944-Spec#94 Posted April 2, 2009 Posted April 2, 2009 Fred, it seems that some 83 and 84 engines got cross drilled rods. Most years did not. You are lucky with that crank. As for the bend rod. Yeah that will cause a cylinder wall to be damaged. It is rare, but does happen from time to time. Quote
