Fresh 88 944 Spec $7995
Apex SPG.com
SAFETY ITEMS-Custom weld-in roll cage, race seat, Sparco steering wheel, Sparco steering wheel adaptor,
6 pt camlock harness, 17 inch rear view mirror,
PERFORMANCE ITEMS-10.2 compression ratio pistons, 968 Sway bars front & rear, upgraded torsion bars, delron bushings in front a-arms, short 5th gear, Light weight battery, Modified steering rack, Koni ajustable shocks, coil over kit, AC eliminator bracket.
THE FOLLOWING MAINTENANCE ITEMS WERE REPLACE RECENTLY: including hoses, rod bearings, water pump, belts, belt rollers, motor mounts, CV joints, wheel bearings, fuel filter, brake calipers rebuilt, modified steering rack, new tie rod ends, new starter, low temp thermostate, new oil pressure relief valve, rebuilt a-arms, new ball joints, hood struts, Spark plug wires, Spark plugs,
Rotor, Distributor cap
OTHER ITEMS OF INTEREST -2 sets of wheels, Interior has been stripped and repainted with trunk paint
This car is optimized to race in Porsche Club of America SP1 class or N.A.S.A. 944spec. Call Mike at 612-805-9227 with any questions.
