jfranci3 Posted April 1, 2009 Posted April 1, 2009 2000 Mustang GT Coupe for sale. 105k 5-speed 4.6 v8 Used for NASA and SCCA track and auto-x events I'm selling my car. It's a great car in most respects, but I'm just not having as much fun as I used to with it and can't justify keeping it. It needs a bit of maintenance that I'm not interested in performing mostly because I don't have a garage (see ugly section). This is a good car for someone looking for a track car, possibly something to build into an AI car, adjust to be competitive in time trails, or part out. The Good: Chassis -Maximum motorsports full length HD subframe connectors -Evolution Motorsports v-brace -Kenny Brown k-member brace -4pt Autopower rollbar -Solid Steering Shaft -Maximum Motorsports Aluminum Steering rack bushings -Maximum Motorsports Strut Tower Brace -Never wrecked, clean title Drivetrain Engine -Ford 4.6 SOHC engine (260hp stock) dyno'd 2 years ago at 260rwhp -Steeda underdrive pulleys -Accufab Upper intake and throttle body -Mangaflow exhaust (x-pipe and catback) -Tuned for premium gas Transmission -Stock Ford 5-speed manual -Steeda shifter Axle -Torsen 28spline t2 diff -Ford 3.73 gear Brakes -Mustang Cobra Front and Rear -Stainless Brake lines (front only) -Carbotech XP12(?) and XP8(?) pads (some spare pads included - need to check my inventory) Suspension Front -Maximum Motorsport Coilover -03 Cobra Coupe Bilstein Struts (1 spare inc) -Maximum Motorsports 4 bolt caster/camber plates -Maximum Motorsprots A-arms fwd offset, delrin bushings -350lb/in springs (I've got other rates if interested) -Steeda BumpSteer Kit Rear -Maximum Motorsports Torque Arm -Maximum Motorsports Lower Control Arms -Maximum Motorsports Panhard Bar -Maximum Motorsports Rear Coilovers -Bilstein HD shocks -225lb/in springs (I've got other rates) Wheels -2 sets of OEM Ford 17x9. Both have cosmetic damage. Curb rash, marks from R&R lug nuts. -Cobra 10th Ann has worn street tires -03 Cobra std has worn r-comps Interior -Recaro Speed seats ($750 add extra, otherwise I'll install oem cloth seats) -5pt harnesses -Rear seat removed -Gutted trunk The bad: -The radio preset buttons are broke -Wheels -2 sets of OEM Ford 17x9. Both are cosmetic damage. One wheel needs replacing (damage from broken lug) -1 set has worn street tires -1 set has worn r-comps -The engine has had 4(?) spark plug holes fixed with timeserts (kit included) -Needs front bearing/hubs replaced (parts included) -Windshield washers squirts don't work -HVAC doesn't blow cool air, AC works great though. (There is a door in the HVAC controls that apparently failed) -Steering wheel not aligned straight, bumpsteer out of adjustment - needs alighnment -My bumper was stolen. I'm missing a trim piece from the front. It's purchased, but on backorder. -I'm the mechanic. I'm not a great mechanic. The ugly: -The car has 8 years of outdoor city living under it's belt. The body panels need some loving. Just about every panel has a nick or scrape....expect the front bumper, that's new. -The engine has a ticking noise in the #8(?) cylinder. It might be nothing, it might be a bent valve, it might be terminal. I haven't been able to investigate because I don't have the garage space. The engine runs fine, but this warrants concern. Spares (I need to double check these) -1 bilstein 03 Cobra strut -2 sets front springs (425, 325lb/in ???) -1 set rear springs -1 new front caliper, one used (side specific) -1 rear caliper (new, side specific) -Some brake pads (1 Front street set, 1 race spare (10% remaining), 1 street rear, 1 race rear ) -Brake duct kit Price $5k. I'm not negotiating at this time. Located in Chicago, IL 60647. No warranty. Jon EDIT: PICS, updated spares list Full album http://s5.photobucket.com/albums/y167/jfranci3/CarSalePics/?albumview=grid Note: Couldn't get good audio on the camera vid. Harness bar not installed. Quote
