racer-025 Posted April 14, 2009 Posted April 14, 2009 I am listing this ad for my racing buddy, John Alchorn. I can answer questions or he can be called directly. I am not sure what I am going to do this season for racing. Lost a little interest last year. Have medical problems within the family at this time. I have 2 race cars, so I decided to sell one of them. 1986 Honda CRX ITB Race car This race car was originally built by Mark Beauregard about 8 years ago. He took approx. 2 years to build it. The chassis was completely striped and put on a rotisserie for the buildup process. During the original build, he spared no expense and rebuilt or replaced just about every component on this car. The original build was documented in photos and was the pinnacle IT example, highlighted in the Tech section of the Improved Touring website. This race car was originally built to contest the SCCA ITC class. I bought it in 2002 and raced it regionally here winning the ITC Championship for 3 straight years. Since then, I modified it to race in the ITB class complete with a Si fuel injected engine. Last year I built a brand new engine and was out just one time only. I modified the engine and brakes to race in the local GT5 class. This car is extremely well built and is in near perfect condition. It has never been wrecked and the only damage it suffered was very minor. Car was repainted 2 years ago. The only current damage is a wrinkled hood. (buddy forgot to put the hood pins in and the hood took out the windshield – hence new windshield). I am now considering my racing options and am offering this race car for a very low price. The original build was in access of $25K and I will now sell it for just $7K CAD (thats only $5700USD). I have a huge/extensive spare parts package that is included with this car. For a low extra cost, I will include several extra wheels and several new Toyo RA-1 tires. Please look at all the photos showing the original build as well as its current condition. Currently, this race car needs nothing and is absolutely 100% race ready. I cannot describe everything that was installed in this racecar. Please view the photos. If you have any questions, simply let me know and I will respond. To modify it back to IT legal, all it would require is the stock Si cam reinstalled (currently has a Tri-flow Colt Cam) and the stock front brakes reinstalled (currently has Integra brakes). Below is an extensive list of its description. Engine; 1500cc 12V MPFI Si (one race weekend). New .040” pistons, rings, bearings, gaskets, seals, timing belt, water pump, etc. Cylinder head has all new valves, seals, etc. Colt Cams Tri-flow cam. DC Sports header & 2-1/4” exhaust w/ high flow muffler. MSD ignition. Dual core Fluidyne alum radiator, new alternator. Gearbox; 4.97 FD with OPM limited slip. New axle seals. Rollcage; 1-1/2x.095” DOM, multipoint, c/w NASCAR door bars. Fuel Cell; ATL 10 gal c/w electric fuel pump & all Aeroquip hoses/fittings. Safety; Aluminum Kirkey Intermediate Road Race seat, 5-point harness & window net. fire extinguisher. Brakes; New Integra front brake rotors, calipers, New Carbotech (Panther) brake pads, SS brake lines with new race DOT 3 brake fluid. Rear brakes are OEM drum. Adjustable brake bias lever. Suspension; Adjustable front camber plates, Custom adjustable rear sway bar, Jackson Racing Torsion bars. Rear drums shimmed for neg. camber, Adjustable panhard bar. Koni Sport (revalved & shortened) dampers, Eibach rear springs. Wheels/Tires; Alum wheel spacers w/ ARP extended wheel studs, 4 Panasport 13x6 rims w/ 4 Toyo Proxes RA-1 205/60R13 tires @ 75% tread left. Misc; Stack Dash (ST8100 Display System) Displays the following: Rev’s, oil press + (low warning), water temp + (high warning), oil temp + (high warning), battery, fuel press, gear shift light. For speed and lap times you require a sensor. Momo removable steering wheel, Wink rear view mirror, side window air vents/tubes. Custom front strut bar. New windshield. Spare Parts included with the race car; There may be more - I got tired of listing things. 3 spare CPU’s 2 brake caliper repair kits 2 spare alternators 4 new rear hub bearings 3 CV joint repair kits Stock Honda windshield 2 front bumpers (w/rebar) 1 front bumper cover 2 rear bumpers (w/rebar) 1 front x-member w/torque tubes 1 front x-member w/o torque tubes 2 steering racks 2 shift stick set ups 1 front sway bar stock 2 left doors 2 right doors 2 rear hatches 2 hoods 1 rear axle assembly (no hubs) Stock fan motor and shroud Fuel injector assembly Front struts Rear brake assemblies Flywheels, clutches Complete dash assembly 2 heater fan assemblies 2 rear spoilers 2 Si grill center pieces 3 front valances fenders (both sides) body side moldings (both sides) stock brake line assemblies (complete) steering columns 3 short axles 3 long axles oil pans internal motor parts valve train parts 8 lower control arms bare block spare pistons and rods complete electrical wiring 2 Si motors 2 Si transmissions 3 wiper motors 3 gas tank covers 1 shifter boot 2 hood supports head lights, tail lights & rear center pieces positive & negative battery leads 2 heater box cables under dash) 1 gauge cluster various interior parts 2 rear hatch supports 2 wiper arm pivots emergency brake cable hardware 6 hood hinges 1 hood latch assembly 4 wiper arm blades 4 front bumper brackets 1 dash pod assembly (no cluster) 1 leather shifter cove, cover plate and knob 1 hatch/fuel release & hardware 1 each hatch/fuel cable 2 door weather strip pieces various motor mounts 2 torque tubes Body rubber Box of distributors = whole and parts Bags of interior parts Bags of electrical parts There are more parts, but I got tired of listing them. All of the above parts, tires and rims come with the car. $7000.00CAD (thats only $5700USD). This is a steal for someone... For and additional $1500, I will include the following: 8 alum rims (6” Wide) 4 alum rims & 4 Toyo tires (only 1 heat cycle – 15 laps) 4 alum rims & 4 Toyo tires (50%) 6 sticker Toyo tires 205-60-13 This Race car is located in Elmsdale, Nova Scotia. If you are looking for a premium early Honda CRX that needs nothing for an incredibly low price. This is it. Go racing today. I may consider a partial delivery. I can be reached at 902-883-7875. Or PM me for an email address. CRX Original Building Photos; http://s241.photobucket.com/albums/ff260/racer-025/CRX%20Original%20Build%20Photos/ CRX Original Finish Photos; http://s241.photobucket.com/albums/ff260/racer-025/CRX%20Original%20Finish%20Photos/ CRX Current Photos; http://s241.photobucket.com/albums/ff260/racer-025/CRX%20Current%20Photos/ Quote
racer-025 Posted May 1, 2009 Author Posted May 1, 2009 c'on, this is cheap. Drop a GSR engine it it!! Quote
Gators2001 Posted July 14, 2009 Posted July 14, 2009 Damn wish you where closer. would be interesting to take a closer look. Quote
racer-025 Posted July 16, 2009 Author Posted July 16, 2009 I could deliver to US/Can border, if that helps any. Quote
