FS: 1995 Mustang GT Camaro-Mustang Challenge race car
Posted (edited)
1995 Mustang GT Camaro-Mustang Challenge race car: $8000 obo
Muscle Mustangs & Fast Fords project car (Jan.-May 2009), finished second in class at 2008 NASA Nationals, 3 wins, 2 seconds in 7 races in 2008
Ground-up rebuild from bare chassis completed in July 2008
Chassis
NASA logbook
Clear Texas title (car is not street-legal)
Six-point rollcage with NASCAR-style door bars and dash bar
Welded Maximum Motorsports full-length subframe connectors
Stripped and painted interior and front clip
Relocated battery
Suspension/Brakes
Maximum Motorsports race-valved Bilstein struts and shocks
MM caster/camber plates
MM adjustable tie-rod ends
MM Extreme Duty rear lower control arms
FRPP upper control arms
1050 front/250 rear springs
Offset delrin front control arm bushings
2003 Cobra steering rack (new in 2008) with MM aluminum rack bushings
Cobra PBR calipers with Brembo rotors, front; SN95 Cobra rear
Note: the car was formerly raced in the American Iron series and still has welded mounts for MM torque arm crossmember and adjustable rear sway bar (parts not included)
Engine:
Dyno’d at 225/294
FRPP 5.0L short-block
E7 heads, HO roller cam
SN95-style induction and intake manifold
Painless Performance wiring harness modified to run A9L EEC-IV computer
SN95 exhaust manifolds, BBK X-pipe, open exhaust with turndowns
C&R aluminum radiator
Fox-style FEAD with underdrive pulleys
3G 130amp alternator
Canton Accusump
Drivetrain
Liberty Gears-built T5 with 2.95 1st gear and Astro Performance 0.79 5th gear, B&M shifter
Stock clutch and flywheel
FRPP aluminum driveshaft and driveshaft loop
8.8-inch rearend with FRPP 3.55 gears
Detroit TrueTrac differential
Moser 31-spline axles
Safety/Other
AIM Mychron 3 Gold Auto data logger/digital gauge (oil pressure and water temp, plus RPM and wheel speed currently logged)
Sparco Evo 2 seat
MOMO steering wheel with Sweet QD coupler
Safety Solutions rightside net
Racetech FIA-approved six-point harness (valid thru 2011)
Handheld fire extinguisher
Lightweight American Racing 16x8-inch wheels (17 pounds per)
Negotiable spares:
Hawk DTC brake pads (two sets front, one set rear)
MM race-valved Bilstein struts and shocks (one season use)
Tokico adjustable struts
New Edelbrock water pump
New set of Toyo R888s
Spare T5 (zero-time rebuild from Liberty and identical to unit in car)
Fresh rebuilt E7 and GT40 heads
Stock short-blocks (2)
SN95-style Cobra/GT40 upper/lower intake manifold
MB Motorsports Competition 16x8 wheels
Located in Milwaukee, WI. Can deliver within reasonable distance. Call 414/236-9776 or email [email protected] for more info and photos.
Post a link to your vimeo video from the 2008 Nationals. I still watch that (among others) to remember what it's like to be out there...
Trades are always considered, but I've already got another race car.
  • 3 months later...
Price dropped to $8000 obo. Ready for Blackhawk next weekend!
Is there room with the cage to install a passenger seat? Are you willing to deliver to Northern, VA?
The stock passenger seat mounts are in place on the floorpan, but you would have to relocate the ECU and wiring that are mounted on a plate bolted to the front pair of studs, which would be easy enough to do. The cage itself would not interfere with a seat. Delivery or shipping could be arranged.
Good idea!
That's good stuff right there.
Good luck with your sale.
  • 4 weeks later...
It's headed to Ohio to run with another organization.
