joeser Posted April 20, 2009 Posted April 20, 2009 (edited) 1999 Monte Carlo bodied Mini Late Model Stock Car Full Tube Chassis 2:18 at VIR full last Feb. on a slow track. Chassis Current NASA logbook 1.75 Round Tube Cage built on square tube frame. NASCAR-style door bars with plate. Very Safe Cage, same as a Full size stock car around driver. Suspension/Brakes/Wheels Tires Front Ford Pinto/Mustang II Spindles and Brakes. Carbo Tech xp10 Pads. Afco Tubular control arms. Fully adjustable mounts. (Adjust Control arm angle roll center etc... without changing ride height) Tubular lower control arms. Mustang II rack and pinion steering. Afco coil over shock/springs Brand New Willwood dual piston master cylinder. Standard StockCar sway Bar. Swap bar diameter to change rate. Rear Toyota Pickup rear. (Like a Ford 9in) 3rd member can be easily swapped to make track side gear ratio changes. Honda Civic Front brakes mounted on the Toyota Rear Adjustable rear brake bias. 3 link rear, all fully adjustable. Afco coil over shock/springs Chassis has been scaled to a 50.1% cross 50/50 F to Rear with 180 lbs driver. 6 13*10 Wheels Hoosier 22x10x13 Road Race Slicks. Will disclose source for used tires (20 bucks a piece) upon sale. Engine VG33E Nissan V6 Schneider Race Cams Holley 2 barrel. Holley fuel pump Carb Intake. Headers with cross over and 2 into 1 side exit exhaust Currently does not run, will need a rebuild or another junkyard engine. Had Low oil pressure and I shut it off at VIR in Feb. Crank is tight/hard to turn. Comes complete carb to oil pan. Uses a vg30e Nissan engine from 84-89 300zx, maxima’s, pathfinders, trucks, quest/villager’s Or a vg33e from xterra’s, frontiers, quest/villager’s Currently has a junkyard vg33e from a 2002 villager installed, will include a good vg33e crank and vg30 block/heads as well. Drivetrain Nissan 300ZX 5 Speed Transmission Stock clutch and flywheel Toyota Rear New Master and Slave Cylinder Safety Kirkey seat with right side head support Has leg support extensions. Current belts window net etc... Fuel Cell Spares 4 heads, Fuel Injection Intake complete. (Plans were to convert to FI) 1 crank 1 vg30e bare block. Adjustable cam gears. Countless tires. New Spindles Extra springs Extra 4.11 3rd member (Rear-end) Car is in Richmond VA. Some say the body is ugly, others love it this way. It’s like a mut. The Chassis is solid. Price reflects the ugliness of the body. Uses five star racing bodies if you want to look sweet. Put in a junkyard Nissan V6 and you will have a super fast car for under 3500 bucks. $3000 for the car + around $500 or so for a good engine. The car is as it came off the track when the current engine expired. Edited October 6, 2011 by Guest Quote
laze1 Posted May 6, 2009 Posted May 6, 2009 What is the wheelbase of this car? What class does it run in NASA? Quote
joeser Posted May 13, 2009 Author Posted May 13, 2009 Wheel base 95” to 97” I run it in Sports Racer in the stinger group. Its really up to you and the group you race with. There is no real class for it so SR is a catch all. Another pro 6 car I know of runs in the SCCA in a GT class. FWIW I has raced against a diasio and prevailed on the old setup. The new setup is faster and much more pleasant to drive on. I have learned more about chassis design and setup from this car in the past 2 years than I have over the past 10 years of racing an IT/PT car. Quote
