944 Control Arms -- Grp Buy
We are doing a group buy with High Strung 44 for their new 944/924/968,951 front control arm, a chromoly steel arm with adjustable end links on the inboard side to allow improved adjustment of camber and caster, plus spherical Teflon coated self lubricating rod ends, OEM 3-bolt Moog ball joints, and sway bar mount bushings.
The spherical joints eliminate binding that occurs on the stock arms, and also reduce the amount of rubber between the chassis and the pavement, making steering and handling more responsive, especially over bumps and undulations.
Here are the pricing details:
$725 for a pair of arms, base price for chromoly tubes,
steel rod ends with Teflon-lined spherical joints, 3-bolt
OEM style ball joints, and all necessary bushings and
spacers to mount to the stock mounting
points. Available for early or late offset, and
primed/painted or bare.
The group buy takes 10% off the listed prices above. The group buy will run from now thru May 15.
If you are interested, email me at [email protected].
