tcoupe Posted April 23, 2009 Posted April 23, 2009 It’s a Modmax Stoker Kit 302CI Professional Build and Balanced Engine ready to drop in with Flashed ECU Call for more details 732-425-4084 Engine 5000 miles with S/C and Custom Tune ECU and engine harness $4000 Engine only $1900.00 Novi 2000 (but will spilt up) ModMax Forged Stroker (3.750") Crank Shaft ModMax Forged 4340 H-Beam Connecting Rods ModMax /CP Forged 17CC Dished Stroker Pistons ModMax Plasma Moly File Fit Rings Ford Racing Windage tray Houston Performance cams Ported Upper intake 52lbs injectors MMR Fuel Rails EGR delete Stock Heads and Lower intake Car Parts Pics http://img13.imageshack.us/gal.php?g=sdc10180v.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; Fasttrack intercooler Vortech Bypass Univer Blow though mass air meter Suspension MMR Road race coilovers 400# 2.5 springs Kenny Brown Upper control arms StangSuspension Lower control arms weight jackers StangSuspension caster camber plates H&R super Race rear springs Tokico illumine 5 way adjustable shocks Drive train Spec light weight fly wheel Spec Stage 4 clutch and stage 5 Pressure plate Pro 5.0 shifter Pro .5.0 firewall adjuster Steeda adjustable clutch quadrant Aluminum ford racing drive shaft Whole rear with Ford Racing 8.8 3.73 rear gears and brakes Brakes New front cobra brakes and rotors Hawk dtc 70 pads Front Hawk 9012 Rear SS bake lines Steeda quick release pins 3” brake ducts Hust line locks Interior 2 Corbeau seats Black 2 Corbeau seat sliders Wild rides custom 4 point roll bar chrome molly Wild rides weld in sub frame connectors 5 point seat belts Raptor Shift light Wheels 4 American Muscle Bulliet wheels 17x9 2 with 255 RA1 and 2 with stock street tires 2 American Muscle Bulliet wheels 17x10.5 both with Nitto 555r Fuel Kenny Bell Boost- a-pump Ford gt intank pump Quote
