FS: 2003 Silverstone 350z track model HPDE/TTB/daily driver
This is my 2003 Nissan 350z track model, I am the second owner. Chassis has 70,000 miles, motor has 40,000, tranny 15,000 and rear end about 10.
Original motor was replaced under warranty by nissan due to oil issues, tranny also replaced due to a bad synchro.
$15,500 for everything including spares, stock parts, race wheels/tires, race brakes.
Engine:
06 air box with K&N filter
Motordyne 5/16th plenum spacer
Motordyne MREV2 low plenum
Motordyne XYZ Y pipe with resonator
Motordyne Shockwave single 3" exhaust
Stryup headers
Berk test pipes
Tunned UTEC piggyback
260hp/ 240tq on Dynojet last March
Upgraded power steering cooler
Suspension:
SPL adjustable upper A-arms
TC Kline double adjustable Koni's
Nissan T2 race springs 690/690 spring rates
Hotchkiss adjustable sway bars
SPL adjustable end links
SPC rear camber arms/toe bolts
New upper spring seats
ARP wheel studs
ALL wheel bearings replaced at 55,000 miles
Brakes:
Stock Brembo 4 piston front, 2 piston rear calipers
Centric blank rotors
Stoptech stainless lines
Carbotech street pads
ALL brake seals replaced last winter
Track:
Raybesto's ST41 front pads (only used for two events)
Raybesto's ST43 rear pads
Stoptech Titanium front backing plates
Spare set of front rotors used for race pads (only used for two events)
Wheels and tires:
Street:
18x8.5 front 18x9.5 rear Bronze NISMO LMGT4 rims with Falken 235/285 tires
Track:
17x10 flat black 5Zigen FN01RC's with 275/40 Nitto NT01's (only used for two events)
5mm, 10mm, 15mm, 20mm wheel spacers
Drivetrain:
JWT clutch
JWT flywheel
Central 20 3.9 gear
Cusco RS LSD
NISMO finned diff cover
Motul LSD fluid changed every 1500 miles
Red-Line fluid in tranny changed every 6 months
Interior:
Autopower weld in roll bar with removable cross/harness bar
Nismo shift knob
Exterior:
Varis intake duct
Spares:
OEM exhaust, cats, suspension
Condition:
Exterior is very clean with only two small dings and some rock chips. Car has never been into a tire wall or any wall, only the occasional spin. Car is VERY clean for a track car and waxed 3 times a year. Car is street legal with all OEM interior. Car will pass inspetion with a change in exhaust/test pipes.
Car has served as a weekend car and track car. I drove it to the track, changed tires, and then back again. It never left me stranded or had any mechanical failures. I'm looking to get a spec car and can't afford two track cars. If you have been to a Mid Atlantic event, then you've probably seen it!
You can e-mail with any questions! [email protected]
Thanks!
Brett
Do you know where this car "classes-out" in NASA? TTA or higher?
Right now it sits a couple of points over TTB. The control arms would need to be put back to stock or offset bushings used instead.
