AustinG Posted May 6, 2009 Posted May 6, 2009 Anyone have some 0800.250.1000 springs that they don't need? lb - 1,000 length - 8" Diameter - 2.5" I need 2. I started with 850's when I installed the 3011's, while anticipating the R888's stiffer sidewall, after driving with both the R888's and the RA-1's, I've come to the conclusion that I need to get a higher rate spring in the rear. I'm looking to move to 1,000lb springs in the rear. Thanks, Austin Quote
ITAIntegraLS Posted May 16, 2009 Posted May 16, 2009 I have a set of 1000Lbs you want 8" x 2.5" I also have 700lbs 8" x 2.5" And a few others i need to check Email me at ItaIntegra @ Hotmail.com Edo Anyone have some 0800.250.1000 springs that they don't need? lb - 1,000 length - 8" Diameter - 2.5" I need 2. I started with 850's when I installed the 3011's, while anticipating the R888's stiffer sidewall, after driving with both the R888's and the RA-1's, I've come to the conclusion that I need to get a higher rate spring in the rear. I'm looking to move to 1,000lb springs in the rear. Thanks, Austin Quote
