TurboShortBus Posted May 12, 2009 Share Posted May 12, 2009 This is a continuation of a previous thread that just became locked without fully answering my initial question: http://www.nasaforums.com/viewtopic.php?f=2&t=27976 Matt is correct. +2 points. Thank you for that reply, Greg. However, what is the reasoning behind this? I can already tell from reading the existing rules that a tubular K-member that does not alter any suspension geometry is +2 points, so that's easy enough, but (I'll restate) I am curious about the reason behind those points, that's all. I feel that I have effectively explained my question in the original thread, so I don't need to go into details again here. Please advise. Mark Quote Link to comment Share on other sites More sharing options...
Members Shawn M. Posted May 12, 2009 Members Share Posted May 12, 2009 This is a continuation of a previous thread that just became locked without fully answering my initial question: http://www.nasaforums.com/viewtopic.php?f=2&t=27976 Matt is correct. +2 points. Thank you for that reply, Greg. However, what is the reasoning behind this? I can already tell from reading the existing rules that a tubular K-member that does not alter any suspension geometry is +2 points, so that's easy enough, but (I'll restate) I am curious about the reason behind those points, that's all. I feel that I have effectively explained my question in the original thread, so I don't need to go into details again here. Please advise. Mark Welp..... My official position on this is that the rule exisits partly because not ALL cars have K members. So not all cars can change them. So if you want to change yours, you take the points for it. The advantage of the aftermarket k-members goes beyond saving weight. Just like Matt said and Greg said. There is your answer. Quote Link to comment Share on other sites More sharing options...
Trevor57 Posted May 12, 2009 Share Posted May 12, 2009 Thats the first reason that even makes sense Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted May 12, 2009 Share Posted May 12, 2009 it'd be very tough to prove it was for weight reduction only anyways... Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted May 12, 2009 Author Share Posted May 12, 2009 Thats the first reason that even makes sense I'm with you on that one. That's all I was looking for...a reply with some sort of explanation for the reason. Thank you, Shawn, for an actual answer. Mark Quote Link to comment Share on other sites More sharing options...
TurboShortBus Posted May 12, 2009 Author Share Posted May 12, 2009 it'd be very tough to prove it was for weight reduction only anyways... Quite honestly, that's the only thing I'd be after, as I don't see how most tubular K-members could be any stiffer than the stock battle ax that's under there (manufacturer designs vary greatly, though). I was looking at it from a weight loss standpoint (since the suspension wouldn't move), and I saw several parallels to zero-point modifications such as removing all HVAC and switching to a lightweight battery. But hey, now that we have an answer, this is all moot anyway! Mark Quote Link to comment Share on other sites More sharing options...
